PlexAmp offline playback
Hi guys
I try to use PlexAmp on offline mode, I wonder why is not possible to have a set of music downloaded to the phone if I like to play with out use my mobile data plan.
It’s cain of sealy that the app works only with streaming.
Why don’t have the ability of download my music and play offline ?
Br
Sorry, what are you talking about?
There is a Download feature. You can download single Albums, a mix of tracks by one particular Artist, or an Artist Radio.
Every type of Radio you can play on the main page.
Also playlists and every mix or Radio you can make with the Mix builder.
I think I know what they’re talking about. I’ve noticed that Plexamp gets pretty busted after not syncing with my server for about a day. At that point, whenever I open the app, it tries to poll the server and fails (because I’m not at home), and then it just falls into an error state and won’t display anything.
I can sometimes get it to play things that I’ve offlined by going to the Downloads section and picking stuff from there, but it actually will still seem to get confused sometimes and assert it can’t play stuff even then.
You also can’t search through the local stuff you’ve downloaded. It seems to require a connection for almost anything, which is pretty baffling. You should definitely be able to fallback to browsing/searching stuff you’ve downloaded to the device.
