Hello,
I would love to have a new option to shuffle between unwatched episodes inside a Show/Playlist.
Use case:
Problem:
I have a The Simpsons Playlist with all the episodes of the show, and I like to use the shuffle them, but sometimes the same episode is played in a short period of time (same day, same week).
Proposed Solution:
A Shuflle Unwatched option that would Shuffle between the unwatched episodes of a Show/Playlist, marking them as watched so they won’t be played again when using this option, unless they are manually marked as unwatched again.
Do you think this could be done?
Thanks you!
