[Feature Request] Slightly Shorten Skip Duration
I’d love to see a preference to change the skip to something slightly under 30 seconds. If for instance I want to skip 1 minute forward, say to skip a show’s opening credits, if they are precisely 60 seconds long and you don’t get the timing perfect you end up skipping into the show’s return, and having to then skip backwards to find the start.
If instead the skip actually moved by say 29 seconds, it would make up for the time lost raising the playback bar and end up closer to the actual time you were aiming for in the first place.
Does this make sense to anyone else, or does this idea sound silly?
Early 2021 clean-up:
