I believe this has been requested by other audiophiles but not sure why it has not been implemented yet. We need to listen to DSD music through ASIO drivers in bit perfect mode, as other Hi-Res music players are able to do as a bare minimum feature. Even foobar can support it. Honestly, before ASIO is supported, I don’t see the point of Plexamp for Windows, the sound quality of the converted PCM is the same as the web player.
we may support sample rate matching and wasapi, asio is less likely, and dsd even less.
