Feature Suggestion For Dashbord view
One thing I’ve noticed is that there is very little opportunity to change how things are displayed in the dashboard. For example if I want the dashbord to open to a particular library’s media I am unable to set it as the default. As well When I am playing a movie that is represented in a couple different libraries (I do this for better organization than just adding them to a collection) then it shows the movie as playing in all 3 libraries from the dashboard. So 3 of the same movies (or 2 depending on how many libraries it’s represented in) making it kind of an ugly dashboard, as well when adding films to a folder that is read in 3 libraries the discover view marks a new film for each. So basically my suggestion is consolidation. If there is a movie playing or added that is the same name and year then only show it once. And maybe have a simpler means of organizing so that we can create new libraries without having to define new folders so that things show up multiple times. Then instead of add to playlist we could have add to library. And if the metadata exists for the same movie but in a different location then just point to that metadata instead of downloading the metadata all over again.
