@Asru said:
It was on Disabled, I switched to Enabled, not Verbose.
Sorry, this is the log level for the web app, which is not relevant.
The setting I mean is under Settings - Server - General - (Show Advanced)
and consists of 2 checkboxes.
One is for enabling ‘debug logging’ (Yes)
and the second is for enabling ‘verbose logging’ (No)
Here is a test:
can you take this whole movie folder with all its files and copy it to a local disk on the Plex server machine?
Then crreate a new movie library and point it to the copied movie.
Do the local extras have subtitles this time?
Could you now create a separate share on your NAS
copy again the whole movie folder into it
But this time remove almost all the extras and leave only a few. take the extras out of their subfolders and edit their file names instead, attach the extra type to their file names
so \Featurettes\Big-Atures.mkv now becomes \Big-Atures-featurette.mkv
remove all other extras and all empty Extras folders too
Update the library.
Does the Extra have subtitles available now?
That doesn’t work. But if I create a new library with the mapped drive (as V:) instead of UNC path all work.
Why do movies work with UNC and extras don’t? Is it a different process for extras? Maybe that one doesn’t have permissions?
