Fedora 34 Plexamp AppImage Segfault
Server Version#: plexmediaserver-1.23.3.4707
Player Version#: tested with 3.4.4 through 3.4.7
When launching the AppImage on Fedora 33 and 34, I get a segault:
treble.node[17955]: segfault at c6456 ip 00000000000c6456 sp 00007fff04e11840 error 14 in treble.node[7f920dd73000+442000]
I have expanded the AppImage and ran it with the same result.
I have tested the versions listed above with the same result.
Any help getting plexamp to work would be appreciated.
Plexamp AppImage is also segfaulting on Fedora 33 when trying to log in. Crashes to gray screen… Here is the core dump:
core.plexamp.1000.83d12131605a4877a904fc7eb3fc6575.432384.1624696150000000.zip (13.4 MB)
Bump.
@anon18523487 @DaveBinM @elan I would like to get this issue fixed but don’t know exactly who to tag.
PlexAmp 3.7 has the same issue.
They don’t care.
Use the flatpak release from the Fedora Software Center. That’s what I use successfully.
What repository did you use? The flathub repository? I could not find it in the fedora flatpak repository.
https://flathub.org/apps/details/com.plexamp.Plexamp
Thanks. That one works great!
