First of all, on my Samsung Galaxy S22 Ultra, the feature, set on Strict, seems to work nicely with the following USB DAC/AMPs:
- FiiO KA3
- FiiO JadeAudio JA11
So props to the devs for making it work with FiiO-branded devices!
Now, an issue I would like to report is related to Sweet Fades. If you have that feature enabled and it goes from a track with a certain sample rate and bit depth into a track with different ones, it cuts the ending of the track to start the next one immediately. A workaround is, of course, to disable Sweet Fades, which I did. But, I have two ideas of approaches to solve that issue in an upcoming update:
- Don’t fade if the next track’s sample rate and/or bit depth is different.
- Force disable Sweet Fades if Strict is selected for bit-perfect playback.
Thank you, and good work so far!
