Feedback on 8.6 and a few questions (nvidia shield)
Thanks. I don’t really use playlists myself so often forget what is there. made bug report for it.
Yes. This update definitely broke the playlists.
Please help. The new UI on the shield is not working when you try to mark a whole show as watched. You can no longer mark a season as watched and since I got my shields both of them hang on rewind most of the time and you have to wait 30 seconds for it to come back. Do you know when and if this will be fixed?
Many of us like to watch movies in different languagues (my kid will watch dubbed where I like original with subs).
The languague for audio used to be displayed on the main page of a movie.
It’s now gone and to add to the pain, you now you have to go to MORE, Playback Settings, change your audio. Then back to square one, More, Playback settings, change subs.
Are ther any plans to display audio language again and make the Audio/Subs panels (that says DTS 5.1 for example) clickable ?
I was hoping you would bring your other apps inline with this one. I actually prefer the previous interface. I had to check if I accidentally opened Emby as this is exactly what their interface was when I used it last.
The one thing I do miss though is when pressing play and being able to choose right then whether to restart or continue where I left off… To restart now, I have to drill into the 3 dot icon then select it.
it should still do that. This happens when i either hit the on screen play button, or hitting play/select on remote when a partially watched episode or movie is selected
Yes, it does. I just saw the “Resume” text below the button and didn’t actually press the button to check.
flocke487, thank you for posting these images. saved me some time to help illustrate my concern.
Plex,
with the latest update, I found that the absence of these movie posters (images) from inside the play lists has made it a little more difficult for my children, who are still learning to read or too young to, to identify which movies they’d like to watch or which they’ve selected. It would be appreciated if these reappeared in a subsequent update or at least have the ability to show the movie poster of the selected movie.
I appreciate the time and consideration.
Thank you kindly.
Plex has completely botched playlists in the new updates on the streaming devices. Being forced to go to the web interface or the player on my computer to modify the playlist is completely asinine.
