Greetings,
Let me first say the new app for Xbox One is beautiful. It looks great, and the organization of libraries and the display of content is much more pleasing to the eye.
That being said, the player controls have suffered quite a bit. Not a day goes by when I haven’t accidentally rewound or skipped to the middle of my show. The player controls need some adjustment. Since left on the stick will rewind regardless of if the “player controls” are actually visible, rewinds can occur in situations I do not think you expected. I’ve had several times when I can pull up the player controls with “A”, but then couldn’t move to the pause button and instead was stuck fast-forwarding. Only solution was to back out and go back into the media - not good.
My suggestion - remove all controls when the player controls are hidden, or at least provide an option to do so. This would eliminate my problem, as my new workflow would be to press “A” or up on the stick to bring up the menu, and then I can move over the command I want to execute. I don’t want to have to guess what the player will do.
