Hello
I put a file into the folder which my Plex Library uses.
Let’s call the video file “Beer.mp4”
When I check my Library or try to use my TV or Roku to go find the file it is not there, but instead there is another video file that is not in the folder, but in fact in another folder, for the example lets call it “Rum.mp4”. Not only that but if I choose that video to watch instead of playing Rum.mp4 (even though I really want to watch Beer.mp4) it plays something completely different like “Scotch.mp4”
Any ideas??
THANKS
You will need to use the correct folder setup and file and folder naming for plex to pick up your media correctly. You did not specify if you were trying to watch a movie or TV show. Make sure your media is setup like below.
TV Shows:
/TV Shows
/Grey's Anatomy
/Season 01
Grey's Anatomy - s01e01.avi
Grey's Anatomy - s01e02 - The First Cut is the Deepest.avi
Grey's Anatomy - s01e03.mp4
/Season 02
Grey's Anatomy - s02e01.avi
Grey's Anatomy - s02e02.mkv
Grey's Anatomy - s02e03.m4v
Movies:
/Movies
/Avatar (2009)
Avatar (2009).mkv
/Batman Begins (2005)
Batman Begins (2005).mp4
Batman Begins (2005).eng.srt
You can read up more on media renaming here
https://support.plex.tv/hc/en-us/categories/200028098-Media-Preparation
In Windows file explorer, make a right-click on that mp4 file and choose
Properties - Details
This incorrect title is probably embedded into the file itself.
Here is how to disregard embedded metadata in Plex:
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - Plex Movie
Settings - Server - Agents - Movies - TheMovieDatabase
Thanks for the idea. I have now tried that too and it still did not work.
Is there a way to have plex just use the file names?
I don’t need it to look to the internet for more information.
I know what the file is, I put it there.
Please don’t give up so quick.
Perform the Plex Dance with all ‘mismatched’ items.
ok Thanks I will try that too
OttoKerner, thanks that Plex Dance worked!
