Server Version#: 1.22.0.4163 running in docker on Unraid
Player Version#: Various
Hi, I have an issue where some files play perfectly on my LAN, but do not play on any remote device. this includes android app, apple TV, Toshiba TV, windows PC, all with recent or latest updates. I believe the issue to be that plex server fails to transcode for remote play, but direct plays locally. Other files, however, transcode perfectly. Table is below of what plays and what doesn’t remotely. All play perfectly locally…
Server is strong: 32 threads (dual Xeon E5 @ 2.6Ghz base), 128 GB Ram, and transcode set to an SSD outside the storage array.
Any ideas out there what is wrong, presumably with the file itself??
thanks for your help.
| does not play | plays | plays |
| Media | Media | Media |
| Duration 42:58 | Duration 43:10 | Duration 2:21:16 |
| Bitrate 3225 kbps | Bitrate 2562 kbps | Bitrate 4410 kbps |
| Width 1280 | Width 1280 | Width 1920 |
| Height 720 | Height 720 | Height 800 |
| Aspect Ratio 1.78 | Aspect Ratio 1.78 | Aspect Ratio 2.35 |
| Video Resolution 720p | Video Resolution 720p | Video Resolution 1080p |
| Container MKV | Container MKV | Container MKV |
| Video Frame Rate 24p | Video Frame Rate 24p | Video Frame Rate 24p |
| Video Profile high | Video Profile high | Video Profile high |
| Part | Part | Part |
| File 1.mkv | File 2.mkv | File 3.mkv |
| Size 991.10 MB | Size 791.80 MB | Size 4.35 GB |
| Codec H264 | Codec H264 | Codec H264 |
| Bitrate 3225 kbps | Bitrate 1922 kbps | Bitrate 3962 kbps |
| Language English | ||
| Bit Depth 8 | Bit Depth 8 | Bit Depth 8 |
| Chroma Location left | Chroma Location left | Chroma Location left |
| Chroma Subsampling 4:2:0 | Chroma Subsampling 4:2:0 | Chroma Subsampling 4:2:0 |
| Coded Height 720 | Coded Height 720 | Coded Height 800 |
| Coded Width 1280 | Coded Width 1280 | Coded Width 1920 |
| Color Primaries bt709 | Color Primaries bt709 | Color Primaries bt709 |
| Color Range tv | Color Range tv | Color Range tv |
| Color Space bt709 | Color Space bt709 | Color Space bt709 |
| Color Trc bt709 | Color Trc bt709 | Color Trc bt709 |
| Frame Rate 23.976 fps | Frame Rate 23.976 fps | Frame Rate 23.976 fps |
| Level 3.1 | Level 3.1 | Level 4.1 |
| Profile high | Profile high | Profile high |
| Ref Frames 4 | Ref Frames 4 | Ref Frames 4 |
| Scan Type progressive | Scan Type progressive | Scan Type progressive |
| Display Title 720p (H.264) | Display Title 720p (H.264) | Display Title 1080p (H.264) |
| Extended Display Title 720p (H.264) | Extended Display Title 720p (H.264) | Extended Display Title 1080p (H.264) |
| Codec EAC3 | Codec EAC3 | Codec AC3 |
| Channels 6 | Channels 6 | Channels 6 |
| Bitrate 640 kbps | Bitrate 448 kbps | |
| Language English | Language English | Language English |
| Audio Channel Layout 5.1(side) | Audio Channel Layout 5.1(side) | Audio Channel Layout 5.1(side) |
| Sampling Rate 48000 Hz | Sampling Rate 48000 Hz | Sampling Rate 48000 Hz |
| Title Surround | ||
| Display Title English (EAC3 5.1) | Display Title English (EAC3 5.1) | Display Title English (AC3 5.1) |
| Extended Display Title English (EAC3 5.1) | Extended Display Title English (EAC3 5.1) | Extended Display Title Surround (English AC3 5.1) |
| Codec SRT | Codec SRT | Codec ASS |
| Title English (SDH) | Display Title English (ASS) | |
| Display Title English (SRT) | Display Title English (SRT) | Extended Display Title English (ASS) |
| Extended Display Title English (SDH) (SRT) | Extended Display Title English (SRT) | Codec ASS |
| Display Title English (ASS) | ||
