I am trying to add files to a sub directory \Featurettes but only a few files show up on plex. Is there some kind of file size limitation? It looks like only the larger sized files are showing up.
Linux does not have a limit.
If you’re trying to add Extras,
- In Settings - [server] - Agents - Show Advanced, did you enable “Local Media Assets” agent? (this is what tells PMS to search for them)
- Have you named them per the naming convention?
- Most importantly, does
PlexMediaServerhave permission to read the files?
https://support.plex.tv/articles/local-files-for-trailers-and-extras/
Can I have a \Featurette subdirectory for TV Shows? Or is there another way to show stuff like “behind the scenes” and “interviews” and the like?
