Will the filters and the sorting options be implemented in the Xbox One version?
If yes,
- Will all of them be available? Filtering per labels?
- Will it be possible to select multiple filters?
Thanks.
If yes,
Thanks.
It’s on the roadmap, but not yet done. Sorry!
It will be the same interface as Roku now has - so you can filter by genre/collection etc. but you will only have one filter available at once.
A suboptimal solution right now is to create a Smart Playlist for the filter in web, and then use that playlist in XB1.
