Server Version#:newest
Player Version#:all
Hello,
I have several media libraries. One of them for a folder where my Dreambox 7080 stores TV recordings. In it are various recordings (movie, series, TV content, …). I want Plex to display all recordings, even if only as filename.
I have played around with the scanners and agents, but have not found a solution.
What can I do? Thanks for your help!
BR
Plex doesn’t do mixed (Movies & TV Series) libraries. Probably your best bet is an “Other Videos” type library. It will not lookup metadata but should display all the videos in that directory.
https://support.plex.tv/articles/200288916-overview/
It won’t cost anything to give it a try and see how it works out for you!
Good luck,
Chris
Thanks for the feedback! I have already tried that, unfortunately without success.
