Fine-tune "Plex Movie" agent?
Historically I get a movie title from IMDB page and use it to name a file (replacing some characters like “:”). Works for me for last 10 years.
So here’s a fine named “Star Wars - Episode V - The Empire Strikes Back (1980).mkv”.
Plex Movie Agent is configured to only use IMDB, other agents are turned off completely on that library.
But the title I get is “The Empire Strikes Back”:
...guid="com.plexapp.agents.imdb://tt0080684?lang=en" librarySectionTitle="Movies" librarySectionID="4" librarySectionKey="/library/sections/4" studio="Lucasfilm" type="movie" title="The Empire Strikes Back" titleSort="Empire Strikes Back" contentRating="PG"...
IMDB and Metacritic list it as “Star Wars: Episode V - The Empire Strikes Back (1980)”, TheMovieDB and Wikipedia use “The Empire Strikes Back”.
How can I force the agent to use IMDB title? I need it for my pet project (syncing IMDB playlists with Plex) that I hope to release some day.
Why don’t you use the IMDb ID for your project? It’s the natural choice when working with the IMDb.
tt0080684 is the IMDB ID, which also appears in the URL when looking at the movie’s page on IMDb: https://www.imdb.com/title/tt0080684/
Thanks, Otto. Sure, IDs are much better option usually.
But is there any way to learn to reconfigure the Agent? I think many users might appreciate that kind of tuning.
my particular case
I am already using IDs. The problem is that guid attribute is not present on XML that comes from %PMS%/library/sections/%library_id%/all, it’s only present in responses from %PMS%/library/metadata/%video_key%, and that means making 1 request per movie, instead of 1 per library. Expected title would give me 2000 times less traffic, and make my plugin architecture very simple.
Did you analyze the source code of ExportTools?
Maybe @dane22 has found a better/faster way?
Sadly OP is correct here, since it’s not exposed on the library level
Due to that, I do paging on the library in pairs of 20, in order to not stress the PMS, as well as have an exclude param about what not to fetch
https://github.com/ukdtom/ExportTools.bundle/blob/master/Contents/Code/init.py
