Server Version#:Windows 10 Pro. Plex Version 1.24.3.5033
Player Version#: App version: 8.23.2.28087 (829873016) on Fire Stick 4k MAX
Logs attached.
Fire Stick 4k Max log.txt (4.0 MB)
Plex Media Server.log (1.9 MB)
Playing movies on new Fire Stick 4k Max, Plex errors out every few minutes and says “An error occurred while attempting to play this video. Please check your connection and try again.”
The same movie plays fine on the Plex app for Samsung TV.
Here is the error in the Fire Stick 4k Max logs.
10-11 08:11:23.396 i: [ExoPlayer][EventLogger] loading [eventTime=196.90, mediaPos=1390.12, window=0, period=0, false]
10-11 08:11:23.557 i: [ExoPlayer][EventLogger] loading [eventTime=197.06, mediaPos=1390.28, window=0, period=0, true]
10-11 08:11:23.589 i: [ExoPlayer][EventLogger] loading [eventTime=197.10, mediaPos=1390.31, window=0, period=0, false]
10-11 08:11:23.653 i: [ExoPlayer][EventLogger] videoDisabled [eventTime=197.16, mediaPos=1390.37, window=0, period=0]
10-11 08:11:23.657 i: [ExoPlayer][EventLogger] audioDisabled [eventTime=197.16, mediaPos=1390.37, window=0, period=0]
10-11 08:11:23.712 i: [FF][MediaPeriod] Releasing.
10-11 08:11:23.714 i: [FF] Loading canceled (released: true)
10-11 08:11:23.714 i: [FFmpeg] [INFO] Demuxer has been successfully interupted.
10-11 08:11:23.716 i: [FF] Releasing demuxer.
10-11 08:11:23.717 i: [FFmpeg] [INFO] Demuxer closing.
10-11 08:11:23.717 i: [FFmpeg] [INFO] Demuxer has been interupted...
10-11 08:11:23.718 i: [FFmpeg] [INFO] Demuxer has been closed, interrupting FFmpeg...
10-11 08:11:23.722 e: [ExoPlayer][EventLogger] playerFailed [eventTime=197.23, mediaPos=1390.37, window=0, period=0
com.google.android.exoplayer2.c1: MediaCodecVideoRenderer error, index=1, format=Format(0, null, null, video/avc, h264, 2112000, null, [1920, 800, 0.0], [-1, -1]), format_supported=YES
at com.google.android.exoplayer2.g1.handleMessage(SourceFile:43)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:193)
at android.os.HandlerThread.run(HandlerThread.java:65)
Caused by: com.google.android.exoplayer2.video.q: Decoder failed: OMX.MTK.VIDEO.DECODER.AVC
at com.google.android.exoplayer2.video.r.m(SourceFile:1)
at com.google.android.exoplayer2.z2.t.render(SourceFile:27)
at com.google.android.exoplayer2.g1.o(SourceFile:14)
at com.google.android.exoplayer2.g1.handleMessage(SourceFile:25)
... 3 more
Caused by: java.lang.IllegalStateException
at android.media.MediaCodec.releaseOutputBuffer(Native Method)
at android.media.MediaCodec.releaseOutputBuffer(MediaCodec.java:2804)
at com.google.android.exoplayer2.z2.w.i(SourceFile:1)
at com.google.android.exoplayer2.video.r.R0(SourceFile:3)
at com.google.android.exoplayer2.video.r.c0(SourceFile:39)
at com.google.android.exoplayer2.z2.t.drainOutputBuffer(SourceFile:32)
at com.google.android.exoplayer2.z2.t.render(SourceFile:16)
... 5 more
10-11 08:11:23.723 e: [Player][ExoPlayer] Playback error detected
10-11 08:11:23.724 i: [Player][Timeline] Handling player error
10-11 08:11:23.724 i: [Player][Timeline] Playback stopped (error: true)
10-11 08:11:23.724 i: [PlaybackTimeBehaviour] Time: 194792 IsStarted: true
10-11 08:11:23.724 i: [ExoPlayer][EventLogger] state [eventTime=197.23, mediaPos=1390.37, window=0, period=0, IDLE]
10-11 08:11:23.725 e: An exception occurred: com.google.android.exoplayer2.c1: MediaCodecVideoRenderer error, index=1, format=Format(0, null, null, video/avc, h264, 2112000, null, [1920, 800, 0.0], [-1, -1]), format_supported=YES
10-11 08:11:23.725 i: [ExoPlayer][EventLogger] isPlaying [eventTime=197.23, mediaPos=1390.37, window=0, period=0, false]
10-11 08:11:23.725 e: Stacktrace: com.google.android.exoplayer2.c1: MediaCodecVideoRenderer error, index=1, format=Format(0, null, null, video/avc, h264, 2112000, null, [1920, 800, 0.0], [-1, -1]), format_supported=YES
... 3 more
... 5 more
10-11 08:11:23.726 i: Fetching [method:GET] https://192.168.1.140:32400/:/timeline?audioStreamID=370927&bufferedTime=328411&duration=5847000&guid=plex%3A%2F%2Fmovie%2F5d776829eb5d26001f1de1d5&key=%2Flibrary%2Fmetadata%2F137995&playbackTime=194792&playQueueItemID=65280&ratingKey=137995&state=stopped&time=1390266&token=...a3Mz&X-Plex-Client-Identifier=6cf8a76822ccd535-com-plexapp-android&X-Plex-Token=...a3Mz&X-Plex-Language=en-us
10-11 08:11:23.732 i: [FFmpeg] [INFO] Demuxer has been interupted...
10-11 08:11:23.733 i: [FFmpeg] [INFO] Demuxer has been closed, interrupting FFmpeg...
10-11 08:11:23.741 i: [FFmpeg] [INFO] Demuxer has been interupted...
10-11 08:11:23.742 i: [FFmpeg] [INFO] Demuxer has been closed, interrupting FFmpeg...
10-11 08:11:23.749 i: [FFmpeg] [INFO] [Cache] Close requested, terminating.
10-11 08:11:23.750 i: [FFmpeg] [INFO] [Cache] Cache has been closed, interrupting AVIO ...
10-11 08:11:23.759 i: [FFmpeg] [INFO] [Cache] Close requested, terminating.
10-11 08:11:23.778 i: [Player][Timeline] Player error not known by server, reporting original player error (or a playback interrupted one)
10-11 08:11:23.779 i: [Player] Error reported: UnknownError (null)
10-11 08:11:23.779 i: [Player][Timeline] Playback stopped (error: false)
10-11 08:11:23.780 i: [PlaybackTimeBehaviour] Time: 194849 IsStarted: true
10-11 08:11:23.782 i: Fetching [method:GET] https://192.168.1.140:32400/:/timeline?audioStreamID=370927&bufferedTime=328411&duration=5847000&guid=plex%3A%2F%2Fmovie%2F5d776829eb5d26001f1de1d5&key=%2Flibrary%2Fmetadata%2F137995&playbackTime=194850&playQueueItemID=65280&ratingKey=137995&state=stopped&time=1390266&token=...a3Mz&X-Plex-Client-Identifier=6cf8a76822ccd535-com-plexapp-android&X-Plex-Token=...a3Mz&X-Plex-Language=en-us
10-11 08:11:23.789 i: [TranscodeSession] Stopping...
10-11 08:11:23.790 i: [Player][Error] Displaying player error...
10-11 08:11:23.791 i: [DialogBehaviour] Showing dialog.
10-11 08:11:23.793 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
10-11 08:11:23.793 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 384
10-11 08:11:23.793 i: [BufferHelper] Segment count: 2457
10-11 08:11:23.794 i: [TranscodeSession] Notifying server that we've stopped
```[Fire Stick 4k Max log.txt|attachment](upload://eDuW27DbAK9LGY1Sc42Xm1dVvUO.txt) (4.0 MB)
