Fire Stick stops playing live tv every few minutes, exits to guide. ([FFmpeg] [ERROR] [tls @ 0x81b7e740] Error in the pull function.)
Thanks @sixones,
Let me know if you need more MPEG .TS streams to test with. I can record more if you need them.
I have no way to replicate the issue with the .TS files because my Fire Stick 4k Plex player does not transcode them, it just direct plays them and they play fine. However the exact same content playing over Live TV will transcode and cause buffering and crashing. But maybe you have some way of forcing transcoding on your end to replicate the issues.
I have this issue as well, lmk if you need more info, glad finally some progress is being made on this annoying issue!
Hi @sixones,
I have some more data points for you.
I ran a bunch of tests while watching the Fire Stick 4k logs. Important parts of 3 logs are below. The errors start at exactly 5 minutes aka 300 seconds. It doesn’t appear to matter which channel I am on or if the channel is HD or SD. It may have to do with the "period, or “window” time as shown in the ExoPlayer EventLogger output lines. Every time these reach 300 the buffering and rewinding starts.
Tests done running latest beta (kepler-armv7a-amazon-fireExo-8.12.0.22522-de81227b.apk)
I hope this helps solve the mystery and find the bug.
Thanks!
 NBC 6.1 HD
START
01-16 17:32:50.726  i: [Player] onPlaybackStarted
01-16 17:32:50.741  i: [ExoPlayer][EventLogger]   period [3.00]
ERRORS
01-16 17:37:51.986  i: [ExoPlayer][EventLogger] videoDisabled [eventTime=308.01, mediaPos=302.69, window=0, period=0]
01-16 17:37:51.987  i: [ExoPlayer][EventLogger] audioDisabled [eventTime=308.02, mediaPos=302.69, window=0, period=0]
01-16 17:37:51.988  i: [ExoPlayer][EventLogger] videoEnabled [eventTime=308.02, mediaPos=302.69, window=0, period=0]
01-16 17:37:51.989  i: [ExoPlayer][EventLogger] audioEnabled [eventTime=308.02, mediaPos=302.69, window=0, period=0]
01-16 17:37:51.993  i: [FF] Seeking outside buffer
01-16 17:37:51.999  i: [ExoPlayer][EventLogger] timeline [eventTime=308.03, mediaPos=302.00, window=0, period=0, periodCount=1, windowCount=1, reason=SOURCE_UPDATE
01-16 17:37:52.000  i: [FF] Loading canceled (released: false)
01-16 17:37:52.001  i: [ExoPlayer][EventLogger]   period [302.00]
01-16 17:37:52.002  i: [ExoPlayer][EventLogger]   window [302.00, true, false]
01-16 17:37:52.003  i: [ExoPlayer][EventLogger] ]
01-16 17:37:52.004  i: [Player][ExoPlayer] onTimelineChanged (Position: 302001 ms, Duration: 302001 ms)
01-16 17:37:52.005  i: [EngineEventManager] onBufferingStarted (isSeeking: false)
01-16 17:37:52.005  i: [TranscodeSession] Updating session status
01-16 17:37:52.007  i: [TranscodeSession] Direct Play
01-16 17:37:52.008  i: [Player][Buffer] Buffering due to network too slow
01-16 17:37:52.009  i: [TranscodeSession] Media choice updated
01-16 17:37:52.010  i: [TranscodeSession] Pausing...
01-16 17:37:52.011  i: [FF] Input has been seeked to 302001745us.
01-16 17:37:52.012  i: [FFmpeg] [INFO] Demuxer is applying pending seek to 312001745 us, original target was 302001745 us.
NBC 5.1 HD (DIFFERENT CHANNEL)
START
01-16 18:04:08.996  i: [EngineEventManager] onPlaybackStarted: 5.1-1610838000000
01-16 18:04:08.998  i: [PlaybackTimeBehaviour] Initialising
01-16 18:04:09.000  i: [PlaybackTimeBehaviour] Starting stopwatch
01-16 18:04:09.159  i: [Player] onPlaybackStarted
01-16 18:04:09.176  i: [ExoPlayer][EventLogger]   period [2.00]
ERRORS
01-16 18:09:11.803  i: [ExoPlayer][EventLogger] videoDisabled [eventTime=307.83, mediaPos=303.04, window=0, period=0]
01-16 18:09:11.805  i: [ExoPlayer][EventLogger] audioDisabled [eventTime=307.83, mediaPos=303.04, window=0, period=0]
01-16 18:09:11.806  i: [ExoPlayer][EventLogger] videoEnabled [eventTime=307.83, mediaPos=303.04, window=0, period=0]
01-16 18:09:11.812  i: [FF] Seeking outside buffer
01-16 18:09:11.813  i: [ExoPlayer][EventLogger] audioEnabled [eventTime=307.84, mediaPos=303.04, window=0, period=0]
01-16 18:09:11.817  i: [ExoPlayer][EventLogger] timeline [eventTime=307.85, mediaPos=302.00, window=0, period=0, periodCount=1, windowCount=1, reason=SOURCE_UPDATE
01-16 18:09:11.818  i: [FF] Loading canceled (released: false)
01-16 18:09:11.820  i: [ExoPlayer][EventLogger]   period [302.00]
01-16 18:09:11.821  i: [ExoPlayer][EventLogger]   window [302.00, true, false]
01-16 18:09:11.822  i: [ExoPlayer][EventLogger] ]
01-16 18:09:11.822  i: [Player][ExoPlayer] onTimelineChanged (Position: 302001 ms, Duration: 302001 ms)
01-16 18:09:11.823  i: [EngineEventManager] onBufferingStarted (isSeeking: false)
01-16 18:09:11.825  i: [TranscodeSession] Updating session status
01-16 18:09:11.826  i: [TranscodeSession] Direct Play
01-16 18:09:11.827  i: [FF] Input has been seeked to 302001745us.
01-16 18:09:11.828  i: [Player][Buffer] Buffering due to network too slow
01-16 18:09:11.830  i: [FFmpeg] [INFO] Demuxer is applying pending seek to 312001745 us, original target was 302001745 us.
01-16 18:09:11.831  i: [TranscodeSession] Media choice updated
01-16 18:09:11.832  i: [TranscodeSession] Pausing...
01-16 18:09:11.834  i: [ExoPlayer][EventLogger] state [eventTime=307.86, mediaPos=302.00, window=0, period=0, BUFFERING]
QUEST 69.5 (SD)
START
01-16 18:12:36.443  i: [EngineEventManager] onPlaybackStarted: 69.5-1610838000000
01-16 18:12:36.450  i: [PlaybackTimeBehaviour] Initialising
01-16 18:12:36.455  i: [PlaybackTimeBehaviour] Starting stopwatch
01-16 18:12:36.536  i: [Player] onPlaybackStarted
01-16 18:12:37.818  i: [ExoPlayer][EventLogger]   period [6.01]
ERRORS
01-16 18:17:45.779  i: [ExoPlayer][EventLogger] videoDisabled [eventTime=316.13, mediaPos=307.71, window=0, period=0]
01-16 18:17:45.781  i: [ExoPlayer][EventLogger] audioDisabled [eventTime=316.14, mediaPos=307.71, window=0, period=0]
01-16 18:17:45.782  i: [ExoPlayer][EventLogger] videoEnabled [eventTime=316.14, mediaPos=307.71, window=0, period=0]
01-16 18:17:45.786  i: [FF] Seeking outside buffer
01-16 18:17:45.787  i: [ExoPlayer][EventLogger] audioEnabled [eventTime=316.14, mediaPos=307.71, window=0, period=0]
01-16 18:17:45.792  i: [FF] Loading canceled (released: false)
01-16 18:17:45.794  i: [FF] Input has been seeked to 301000734us.
01-16 18:17:45.795  i: [FFmpeg] [INFO] Demuxer is applying pending seek to 311000734 us, original target was 301000734 us.
01-16 18:17:45.797  i: [ExoPlayer][EventLogger] timeline [eventTime=316.15, mediaPos=301.00, window=0, period=0, periodCount=1, windowCount=1, reason=SOURCE_UPDATE
01-16 18:17:45.798  i: [ExoPlayer][EventLogger]   period [301.00]
01-16 18:17:45.799  i: [ExoPlayer][EventLogger]   window [301.00, true, false]
01-16 18:17:45.800  i: [ExoPlayer][EventLogger] ]
01-16 18:17:45.802  i: [Player][ExoPlayer] onTimelineChanged (Position: 301000 ms, Duration: 301000 ms)
01-16 18:17:45.804  i: [EngineEventManager] onBufferingStarted (isSeeking: false)
01-16 18:17:45.805  i: [TranscodeSession] Updating session status
01-16 18:17:45.806  i: [TranscodeSession] Direct Play
01-16 18:17:45.807  i: [TranscodeSession] Media choice updated
01-16 18:17:45.808  i: [TranscodeSession] Pausing...
01-16 18:17:45.809  i: [Player][Buffer] Buffering due to network too slow
01-16 18:17:45.810  i: [ExoPlayer][EventLogger] state [eventTime=316.15, mediaPos=301.00, window=0, period=0, BUFFERING]
I’m seeing this occasionally on Chromecast with Google TV. If the plex dashboard doesn’t show the stream, it will always stop after a few minutes. Right now it is stopping when trying to watch NBC but CBS works fine.
Something else weird is that if I play NBC it doesn’t show up in the dash. If I play CBS, that does show. If I switch back to NBC, the dash still shows that I’m watching CBS. It will still stop playing after a few minutes though and then the dash shows nothing.
Edit: If I switch to Play Original Quality the stream immediately shows up on the dashboard and the issue goes away. It seems to specific to transcoding certain streams.
If it helps, the client version is 8.11.2286 and PMS is 1.21.1.3830
Hi @sixones,
I just tried the latest Beta from today kepler-armv7a-amazon-fireExo-8.12.0.22562-284fd051.apk
No difference with this issue. Fire Stick 4k starts pausing and rewinding on its own at exactly 5 minutes / 300 seconds. When Period [.] and Window [.] reach 300. This happens every time with transcoding live tv.
Let me know if there is anything I can do.
Thanks.
Hi @sixones,
I was just looking through my PMS log files and noticed that when I start watching Live TV I get this message with DEBUG turned on. This lines up with the buffering and rewinding starting at 300 seconds on the Fire Stick 4k.
Any idea what this 300 second timer is used for? Why do we want to stop after 300 seconds?
Jan 16, 2021 16:28:08.454 [2008] DEBUG - [Grabber/6.1-c2ba770c8a492cb4-com-plexapp-android] Setting timer to stop grab of 'Live TV - Session c2ba770c8a492cb4-com-plexapp-android’ on channel 6.1 in 300 seconds.
no. Just watch live tv - start on an SD channel and do not switch channels. A few mins later the stream will stop.
I can repeat this 100% on 3 fire TV 4ks, 2 fire TV 2020s and a fire TV cube 2ND gen.
as folks have discussed, the tell-tale sign that it’s going to stop is a missing entry on the dashboard. After a few minutes some scheduled event “cleans up” the rogue stream, dumping us back to the tv guide.
You’ll see a few warnings:
Failed to find consumer befa4d0408cb18ed-com-plexapp-android for session 5d6c8aa8-7aa6-41b2-aab7-dadfaf1a43f5
some debug:
Jan 20, 2021 00:00:43.917 [0x7f3199a4f700] Debug — Completed: [10.0.4.123:58372] 200 GET /video/:/transcode/universal/session/befa4d0408cb18ed-com-plexapp-android/base/index.m3u8 (18 live) TLS 1ms 15279 bytes (pipelined: 238)
Jan 20, 2021 00:00:44.253 [0x7f311d64a700] Debug — Request: [127.0.0.1:34626 (Loopback)] PUT /video/:/transcode/session/5d6c8aa8-7aa6-41b2-aab7-dadfaf1a43f5/0bc4141d-a151-4245-99d1-508dc3d0bece/progress?progress=-1.0&size=-22&remaining=-1&speed=0.0 (18 live) Signed-in Token (Rooey) (range: bytes=0-)
Jan 20, 2021 00:00:44.254 [0x7f3199a4f700] Debug — Completed: [127.0.0.1:34626] 206 PUT /video/:/transcode/session/5d6c8aa8-7aa6-41b2-aab7-dadfaf1a43f5/0bc4141d-a151-4245-99d1-508dc3d0bece/progress?progress=-1.0&size=-22&remaining=-1&speed=0.0 (18 live) 1ms 355 bytes (pipelined: 470) (range: bytes=0-)
Jan 20, 2021 00:00:44.460 [0x7f3183af9700] Debug — Subscription: Timing out idle sub with id 3666 for session befa4d0408cb18ed-com-plexapp-android
Jan 20, 2021 00:00:44.460 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Recording for 'Live TV - Session befa4d0408cb18ed-com-plexapp-android' on channel 006 stopped with status complete.
Jan 20, 2021 00:00:44.460 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Using recording status.
Jan 20, 2021 00:00:44.460 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] This was a rolling sub, not assimilating.
Jan 20, 2021 00:00:44.460 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Grabber: Operation for 'Live TV - Session befa4d0408cb18ed-com-plexapp-android' on channel 006 completed with status complete (Success)
Jan 20, 2021 00:00:44.460 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Activity: Ended activity a52fee03-17ee-4203-a0d6-c66d951e7f21.
Jan 20, 2021 00:00:44.460 [0x7f311f159700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Activity: updated activity 184f5239-342c-4e86-9389-cd3dc0928dbe - completed 100.0% - Refreshing Sub
Jan 20, 2021 00:00:44.460 [0x7f311f159700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Activity: Ended activity 184f5239-342c-4e86-9389-cd3dc0928dbe.
Jan 20, 2021 00:00:44.462 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Grabber: Cleaning up rolling grab for channel 006.
Jan 20, 2021 00:00:44.462 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Recorder: No more consumers, stopping.
Jan 20, 2021 00:00:44.463 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Recorder: Asked to stop recording 'Live TV - Session befa4d0408cb18ed-com-plexapp-android' on channel 006.
Jan 20, 2021 00:00:44.463 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Recorder: Stopping transcode session.
Jan 20, 2021 00:00:44.463 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Killing job.
Jan 20, 2021 00:00:44.463 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Signalling job ID 16565 with 9
Jan 20, 2021 00:00:44.463 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Job was already killed, not killing again.
Jan 20, 2021 00:00:44.463 [0x7f311f447700] Debug — HTTP requesting GET http://10.0.4.192:80/discover.json
Jan 20, 2021 00:00:44.463 [0x7f3183af9700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Stopping transcode session 5d6c8aa8-7aa6-41b2-aab7-dadfaf1a43f5
Jan 20, 2021 00:00:44.464 [0x7f319bd48700] Debug — Jobs: '/volume1/@appstore/Plex Media Server/Plex Transcoder' exit code for process 16565 is -9 (signal: Killed)
Jan 20, 2021 00:00:44.464 [0x7f319a02b700] Debug — [Grabber/006-befa4d0408cb18ed-com-plexapp-android] Grabber: Freed a tuner on device://tv.plex.grabbers.hdhomerun/125208CF (now 4 available)
Then finally another warning:
Got a request to stop a transcode session without a session GUID (or with an invalid one).
Plex support any updates on this??
Hi @sixones,
I just tested the latest Fire Stick 4k beta (kepler-armv7a-amazon-fireExo-8.12.0.22620-385eb9e8.apk).
There is no difference. Live TV still starts hanging and rewinding at exactly the 5 minute mark (300 seconds). Is this bug being actively looked into? Is there anything else I can do to help get this moving?
Thanks.
I have been able to replicate the issue and have a fix, will try and prepare a build today that you can try out.
Spectacular! Thank you for your attention to this bug @sixones
This build should solve the various issues mentioned for Live TV;
Fire TV / SHIELD Tube / armv7 https://artifacts.plex.tv/android-experimental/8.13.0.22653-fb3fc136/PlexForAndroid-8.13.0.22653-fb3fc136-Armv7aAmazonFireExo.apk
SHIELD / arch64 https://artifacts.plex.tv/android-experimental/8.13.0.22653-fb3fc136/PlexForAndroid-8.13.0.22653-fb3fc136-Arm64v8aGooglePlayStdExo.apk
Hi @sixones,
I just tested App version: 8.13.0.22653 (819300312).
Unfortunately it did not fix the issue. Fire Stick 4k started pausing and rewinding at 300 seconds, same as before.
Let me know if you need the full log. The relevant part is below.
01-22 11:59:47.958  i: [ExoPlayer][EventLogger] videoDisabled [eventTime=314.17, mediaPos=307.18, window=0, period=0]
01-22 11:59:47.959  i: [ExoPlayer][EventLogger] audioDisabled [eventTime=314.17, mediaPos=307.18, window=0, period=0]
01-22 11:59:47.960  i: [ExoPlayer][EventLogger] videoEnabled [eventTime=314.17, mediaPos=307.18, window=0, period=0]
01-22 11:59:47.963  i: [ExoPlayer][EventLogger] audioEnabled [eventTime=314.18, mediaPos=307.18, window=0, period=0]
01-22 11:59:47.964  i: [FF] Seeking outside buffer
01-22 11:59:47.969  i: [FF] Loading canceled (released: false)
01-22 11:59:47.970  i: [ExoPlayer][EventLogger] timeline [eventTime=314.18, mediaPos=302.00, window=0, period=0, periodCount=1, windowCount=1, reason=SOURCE_UPDATE
01-22 11:59:47.972  i: [ExoPlayer][EventLogger]   period [302.00]
01-22 11:59:47.973  i: [ExoPlayer][EventLogger]   window [302.00, true, false]
01-22 11:59:47.974  i: [ExoPlayer][EventLogger] ]
01-22 11:59:47.975  i: [Player][ExoPlayer] onTimelineChanged (Position: 302001 ms, Duration: 302001 ms)
01-22 11:59:47.980  i: [EngineEventManager] onBufferingStarted (isSeeking: false)
01-22 11:59:47.981  i: [FF] Input has been seeked to 302001733us.
01-22 11:59:47.982  i: [TranscodeSession] Updating session status
01-22 11:59:47.983  i: [FFmpeg] [INFO] Demuxer is applying pending seek to 312001733 us, original target was 302001733 us.
01-22 11:59:47.984  i: [TranscodeSession] Direct Play
01-22 11:59:47.985  i: [Player][Buffer] Buffering due to network too slow
01-22 11:59:47.987  i: [TranscodeSession] Media choice updated
01-22 11:59:47.988  i: [TranscodeSession] Pausing...
Hi @sixones ,
I also just tried Plex for Android 8.12.0.22657-beta that @ManuelPG just posted and that doesn’t fix the issue either. Fire Stick 4k still plays live TV for 300 seconds then starts pausing and jumping backwards continuously until it finally crashes. Same as before. Let me know if you need any additional logs.
Thanks.
Apologies, that particular issue I haven’t been able to replicate or find a solution on yet. Would you be able to let me know your server version? And whether or not your using refresh rate or resolution switching?
The other issues, infinite spinner after a few minutes / airing change, transcoded playback ending after a few minutes should be resolved in the build I posted.
Hi @sixones,
I’m running PMS Version 1.21.1.3876 on Windows 10 Pro. Everything on the Fire Stick 4k Plex app is set to default, so both of those are off. Let me know if I can do anything to help.
With new build on Shield64, infinite spinner into crash or being kicked out into guide does not happen any longer. However, the “looping” issue persists regardless of transcode status (if I turn CC off (direct play) it still loops after a certain amount of time)
All settings default on app. Server version 1.21.1.3830
logging.txt (1.1 MB)
I’m getting the same issue as jg121212 with the beta version you posted, 8.13.0.22653-fb3fc136, I’m running 1.21.2.3918 on the server, and for refresh rate and resolution switching those are on default. logging jan22 8:36.txt (692.8 KB) Would one of us sharing Live TV access help?
@sixones,
Yes, @NGTmeaty has the same exact thing going on in his logs but he has a Chromecast, not a Fire Stick 4k.
After exactly 300 seconds, when transcoding, it starts with the “[FF] Seeking outside buffer”, pausing, and seeking 10 seconds errors.
It looks like his is transcoding due to closed captions being on.
Pertinent part of his logs.
01-22 20:17:02.624  i: [ExoPlayer][EventLogger] droppedFrames [eventTime=307.18, mediaPos=301.97, window=0, period=0, 23]
01-22 20:17:02.665  i: [ExoPlayer][EventLogger] videoDisabled [eventTime=307.22, mediaPos=301.97, window=0, period=0]
01-22 20:17:02.667  i: [ExoPlayer][EventLogger] audioDisabled [eventTime=307.22, mediaPos=301.97, window=0, period=0]
01-22 20:17:02.671  i: [ExoPlayer][EventLogger] videoEnabled [eventTime=307.22, mediaPos=301.97, window=0, period=0]
01-22 20:17:02.713  i: [FF] Seeking outside buffer
01-22 20:17:02.724  i: [ExoPlayer][EventLogger] audioEnabled [eventTime=307.28, mediaPos=301.97, window=0, period=0]
01-22 20:17:02.739  i: [PlaybackTimeBehaviour] Time: 299910 IsStarted: true
01-22 20:17:02.746  i: [FF] Loading canceled (released: false)
01-22 20:17:02.747  i: [ExoPlayer][EventLogger] timeline [eventTime=307.30, mediaPos=301.97, window=0, period=0, periodCount=1, windowCount=1, reason=SOURCE_UPDATE
01-22 20:17:02.748  i: [ExoPlayer][EventLogger]   period [303.00]
01-22 20:17:02.748  i: [ExoPlayer][EventLogger]   window [303.00, true, false]
01-22 20:17:02.749  i: [ExoPlayer][EventLogger] ]
01-22 20:17:02.750  i: [Player][ExoPlayer] onTimelineChanged (Position: 301972 ms, Duration: 303002 ms)
01-22 20:17:02.751  i: [FF] Input has been seeked to 301972223us.
01-22 20:17:02.752  i: [EngineEventManager] onBufferingStarted (isSeeking: false)
01-22 20:17:02.753  i: [FFmpeg] [INFO] Demuxer is applying pending seek to 311972223 us, original target was 301972223 us.
01-22 20:17:02.754  i: [TranscodeSession] Media choice updated
01-22 20:17:02.755  i: [TranscodeSession] Pausing...
01-22 20:17:02.756  i: [ExoPlayer][EventLogger] state [eventTime=307.30, mediaPos=301.97, window=0, period=0, BUFFERING]
01-22 20:17:02.757  i: [ExoPlayer][EventLogger] isPlaying [eventTime=307.30, mediaPos=301.97, window=0, period=0, false]
01-22 20:17:02.758  i: [ExoPlayer][EventLogger] videoInputFormat [eventTime=307.31, mediaPos=301.97, window=0, period=0, id=0, mimeType=video/avc, bitrate=9514000, codecs=h264, res=1280x720, fps=59.94006]
01-22 20:17:02.760  i: [ExoPlayer][EventLogger] audioDecoderInitialized [eventTime=307.31, mediaPos=301.97, window=0, period=0, Plex.Audio.AC3]
01-22 20:17:02.761  i: [ExoPlayer][EventLogger] audioInputFormat [eventTime=307.32, mediaPos=301.97, window=0, period=0, id=1, mimeType=audio/ac3, bitrate=9514000, codecs=ac3, channels=6, sample_rate=48000, language=english]
01-22 20:17:02.766  i: [TranscodeSession] Updating session status
01-22 20:17:02.768  i: Fetching [method:GET] https://192.168.1.33:32400/transcode/sessions/227c56d6a7e240e8-com-plexapp-android?X-Plex-Token=...UHiN
01-22 20:17:02.773  i: [FFmpeg] [INFO] [https @ 0xc5d05800] Opening 'https://192-168-1-33.9988c106981e4b6caaacf3965207ef9d.plex.direct:32400/video/:/transcode/universal/session/227c56d6a7e240e8-com-plexapp-android/base/index.m3u8?X-Plex-Incomplete-Segments=1' for reading
01-22 20:17:02.780  i: [TranscodeSession] Resolution: -1x-1, Video: Transcode, Audio: Remux, Speed: 0.600000, Throttled: false
Do you have an idea of when these fixes will be released?
Thanks for looking into it by the way.
