Server Version#: latest available
Player Version#: latest available
Im using the latest Plex with Synology NAS DS918+.
I have tried using several different Fire TV devices and none of them work anymore! It just can’t play anymore.
I did the following and it still doesn’t work:
I reinstalled the app
Tried local streaming and remote streaming
Tried direct streaming and transcoding streaming
Tried several different videos, that worked previously
Tried restarting the NAS
Anything else I can do?
Plex works on my iPad and iPhone flawlessly.
It also works on my NVidia shield TV Pro
so, there is nothing we can do? just wait until plex releases an update? this really sucks. Why do they always add ■■■■■■ features no one wants and then BREAK the most ESSENTIAL feature?
Everyone: Stay on 7.27 . If you can to back a bit earlier, go for it.
Even I’m sticking there.
I am annoyed and am bringing this up with management today in staff meeting.
@ChuckPa this issue is a bit unrelated but is still present over six months after the team was made aware. Any chance you can look it over and provide an update? To me it seems to be a pretty big issue that Plex Media Server can no longer detect the audio bitrate when using modern versions of MKVToolNix. It’s still causing issues for almost all my Fire TV devices
Input #0, matroska,webm, from 'Fantastic Beasts The Crimes of Grindelwald (2018).mkv':
Metadata:
title : Fantastic Beasts: The Crimes of Grindelwald
encoder : libebml v1.3.10 + libmatroska v1.5.2
creation_time : 2020-03-15T22:29:00.000000Z
Duration: 02:20:59.46, start: 0.000000, bitrate: 28924 kb/s
mediainfo
Complete name : Fantastic Beasts The Crimes of Grindelwald (2018).mkv
Format : Matroska
Format version : Version 4
File size : 28.5 GiB
Duration : 2 h 20 min
Overall bit rate mode : Variable
Overall bit rate : 28.9 Mb/s
Movie name : Fantastic Beasts: The Crimes of Grindelwald
Encoded date : UTC 2020-03-15 22:29:00
Writing application : mkvmerge v44.0.0 ('Domino') 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : Yes
Forced : No
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Maximum bit rate : 4 953 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Title : TrueHD Atmos 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 452 MiB (2%)
Title : AC3 5.1-EX
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Title : English (SDH)
Language : English
Default : No
Forced : No
