Server Version#: 1.30.0.6486
Player Version#: unknown/latest
My firestick isnt showing any media from my server on the home page, I need to navigate to the server select and then I can view my media. All other players (including firestick 4K) work fine.
The same as in the post below?
If so, you’re not the only one. There are at least half a dozen report on the forum and reddit.
All Android TV clients seem affected, so do not be surprised if it happens to the FireStick 4K as well.
The Plex Android team is aware of the problem.
Server Version: Version 1.30.0.6486
Player version: 9.13.0.37059
Within the last week I’m having an intermittent problem with both my shield clients. The Client boots to an empty home screen that just says “No Items to Display this directory appears to be empty.” The interface is completely frozen and I can’t do anything other than force close the app. Launching the app again just results in the same broken interface. Rebooting the shield also doesn’t make a difference.
If I come back to it s…
looks like similar problem thanks, the 4k was off for a while so probably still running an older version so thats why it still works i bet.
