FireTV client audio track off by one when direct playing
I stream mp4s from my Synology NAS without problem to my ios devices, PCs, PS4, etc. But when I stream to my Fire Stick 4k or Cube, the device tries to play the audio track with an index one higher than it should. That means the wrong track, no sound if there is only one track, and inability to select the actual audiotrack when it is the first among many.
The only workaround is defeating direct play by forcing an unnecessary conversion to a different video format.
Running latest public server/client.
Any advice?
To add a few more details:
Playing the correct soundtrack is perfectly possible, unless it is the first one in the file by selecting another track manually which is then (mis-)played as the track you wanted,
In the same circumstances, the subtitle VOBSUB tracks also are off by one.
The server is a Synology DS1019+.
Again, it plays fine on everything except the FireTV Plex client.
Here is the MediaInfo of a file that exhibits this issue,
General
Complete name : XXX.mp4
Format : iso4
Codec ID : iso4
File size : 747 MiB
Duration : 43mn 58s
Overall bit rate : 2 376 Kbps
Movie name : XXX
Screenplay by : XXX
Genre : Thriller
Encoded date : 2009
Writing application : MakeMP4 7.0 on Wednesday, January 06, 2021, at 15:02:10
Cover : Yes
Comment : XXX
hdvd : 1
tvsn : 2
tves : 7
stik : 10
tven : XXX
tvsh : XXX
desc : XXX
ldes : XXX
Video
Format : hvc1
Codec ID : hvc1
Duration : 43mn 57s
Bit rate mode : Variable
Bit rate : 1 924 Kbps
Maximum bit rate : 19.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Bits/(Pixel*Frame) : 0.039
Stream size : 605 MiB (81%)
Title : 265:lang=eng:fps=23.976023976023978:dur=2638.72@GPAC1.0.1-rev0-gd8538e8a-master
Language : English
Encoded date : UTC 2021-01-06 23:02:10
Tagged date : UTC 2021-01-06 23:02:17
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 43mn 58s
Bit rate : 102 Kbps
Maximum bit rate : 142 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 32.1 MiB (4%)
Title : Stereo
Language : Portuguese
Encoded date : UTC 2021-01-06 00:27:39
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 43mn 58s
Bit rate : 288 Kbps
Maximum bit rate : 381 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Stream size : 89.6 MiB (12%)
Title : Surround 5.1
Language : English
Encoded date : UTC 2021-01-06 00:25:59
Text #1
Format : VobSub
Codec ID : subp
Codec ID/Info : The same subtitle format used on DVDs
Duration : 43mn 53s
Bit rate : 12.8 Kbps
Stream size : 4.02 MiB (1%)
Title : idx:lang=eng:dur=2638.72@GPAC1.0.1-rev0-gd8538e8a-master
Language : English
Encoded date : UTC 2021-01-06 23:02:16
Text #2
Format : VobSub
Codec ID : subp
Duration : 43mn 53s
Bit rate : 10.8 Kbps
Stream size : 3.38 MiB (0%)
Title : idx:lang=fra:dur=2638.72@GPAC1.0.1-rev0-gd8538e8a-master
Language : French
Text #3
Format : VobSub
Codec ID : subp
Duration : 43mn 53s
Bit rate : 10.7 Kbps
Stream size : 3.37 MiB (0%)
Title : idx:lang=spa:dur=2638.72@GPAC1.0.1-rev0-gd8538e8a-master
Language : Spanish
Text #4
Format : VobSub
Codec ID : subp
Duration : 43mn 53s
Bit rate : 12.6 Kbps
Stream size : 3.97 MiB (1%)
Title : idx:lang=por:dur=2638.72@GPAC1.0.1-rev0-gd8538e8a-master
Encoded date : UTC 2021-01-06 23:02:17
Text #5
Format : VobSub
Codec ID : subp
Duration : 4s 473ms
Bit rate : 569 bps
Stream size : 318 Bytes (0%)
Text #6
Format : Apple text
Codec ID : text
Duration : 43mn 58s
Bit rate : 1 bps
Stream size : 266 Bytes (0%)
Encoded date : UTC 2021-01-06 23:02:29
Tagged date : UTC 2021-01-06 23:02:29
Menu
00:00:00.000 : Chapter 01 (0m 0s)
00:00:32.240 : Chapter 02 (0m 32s)
00:02:55.717 : Chapter 03 (2m 55s)
00:15:06.530 : Chapter 04 (15m 6s)
00:20:24.431 : Chapter 05 (20m 24s)
00:28:07.227 : Chapter 06 (28m 7s)
00:37:47.682 : Chapter 07 (37m 47s)
00:43:18.679 : Chapter 08 (43m 18s)
Encoded_Date : UTC 2021-01-06 23:02:10
Tagged_Date : UTC 2021-01-06 23:02:29
