FireTV does not display my content only new plex content
Anyone have trouble getting their local content to show up on fireTV after the new plex feature with movies and tv and podcasts? I see my pc listed, but there’s no content displayed. However, iphone , appletv and roku have no problem displaying my content. I’ve reinstalled the app and still have same issue.
-G
Same here. Both apple tv’s showing only new plex tv/movie content, won’t connect to server. Working fine on pc, and now ps4. Restarted everything, nada.
The standard response:
Have you endured the ‘Pinning Process’ yet?
Fun Times:
https://support.plex.tv/articles/customizing-the-apps/
Noteworthy is that FireTV is absent from that list, however it goes kinda the same after you click “More” at the bottom of the sidebar, find your server and pin your libraries.
You may or may not need to reset the Home Page - to get the basic and useful hubs - and you may or may not need to remove a bunch of unwanted and ‘automatic’ hubs - and you may or may not need to select ‘Automatic’ or ‘Manual’.
If you have one server, or access to one, it should be there (‘More’), but you have to pin your libraries to the sidebar (for some reason). If you have more than one server, or access to several - yep - you have to pin those libraries as well.
IF - you have played your cards right - and have a sidebar and home screen - you can ‘Re-Order’ the final sidebar list - those ‘Dots’ are useful in this case.
You can remove some or all of the Plex stuff from the sidebar - or you can disable any of it permanently by visiting ‘Settings/Online Media Sources’ on the server machine. <— That works for you, but Users not in your Home will have to do it for themselves.
See? Fun Times.
