Fire TV 4k doesn't see updated libraries
Server Version#: 4.22.3
Player Version#: 7.30.2.16712
I initially setup 3 libraries in plex and the tv stick saw them and has been fine. I then added a tv shows library and this will not show up. I have cleared the cache in the tv stick app settings but still no good. I suspect if i reinstalled the app it will then show up. But don’t want to keep reinstalling every time i need to make library changes.
Any one know what I need to do to get the plex app to see its full library list?
You’re likely looking at just the pinned libraries you set up when you first installed the app on the Fire TV. You need to go to the “More+” at the bottom and choose your server there, and then you will see the new TV library and you can pin it so it appears on the home screen with the others.
