FireTV FF / Rewind Change
I believe this is more of a tweak than a feature request since the functionality is already there. Currently on the Fire TV you if you want to fast Forward or Rewind and have the dialog showing the position in the show you must first press the center button to display the position indicator. Once the indicator is displayed you must then press the outer ring right or left to get to fast forward or rewind. Then back to the center ring to make the fast forward or rewind happen. This is a lot of button presses to simply skip ahead or rewind.
My request is to simply display the position indicator when the outer ring is pressed. The fast forward / rewind already works using the ring, I just need the indication to display for a few seconds.
Kudos on all of the new features and bug fixes… Once the grid style guide is here my family will be all in on Plex. Finally one program that can really do it all.
