Firmware Upgrade Problem
I have accepted the system to download the latest firmware for my QNAP TS0869-RP 2 days ago, and since then I have a message on the screen saying “updating system 30%” , and I can’t do anything about it!
I am afraid of shutting down the NAS.
What can I do to fix this?
Did you try the QNAP forum ? Or did you open a ticket with QNAP ? Your problem seems to be QTS related and not PMS related.
Have the same problem…
New browser window…
Go to QNAP center, and select shutdown
Upgrade will then be aborted
(Or did for me)
/T
I did as dane22 suggested above. Shutdown the Nas. Pulled the plug. Rebooted it no problem. Then ran a file check before restarting the update process. All good.
