There is a discussion about almost every one of these items on the forum, which you could have read prior to buying a PlexPass.
Granted, a lot of those discussions occur in PlexPass only forums, but Yea. This belongs more in the general section, where it will really get seen.
Regarding your issues, it sounds like they mainly revolve around sync and music. Sync is still technically in beta, and does have some problems. Re music, plex really has a long way to go in the way of music. Hopefully one day, but the focus is really on video content now, I think.
Some of your suggestions are limited by the operating systems, like reinstalling on iOS, there’s no way to save data after uninstalling, no way around that.
I spend a lot of hours every day on a computer, if I wanted to read all the plex forum to verify every plexpass feature describe here
that will take a lot of time....anyway I choose to pay for plexpass so I do not have to spend too much time on xbmc forums to customize it.
My suggestion are to help to make it a great product from my point of view, right now, to me, there is not much added value as it is today compare to the free version.
I understand adding hardware bring more customers but I believe solid foundation are more important with a good set of feature that are rock solid (sync is an important PlexPass feature to me).
All my comments are not just about music (even if music is advertise here https://plex.tv/features)
Note:
- It will be nice to fix the Sync bugs I reported.
- Pity the sync file can't be copied or propose to 'not erase' them when we re-installing the app, then I would suggest to save the list of uids of what has been sync on the server and to propose to re-sync on any device (so re-convert the movies automatically if needed etc...if there is no way to do it, I guess , that might be an issue for the long run as people might want to sync a bunch of movies or music and doing this manually takes time, loosing that work isn't good, and time is what I do not have and crave for)
For the best of plex
w
Why are you reinstalling the app on iOS often enough for that to be an issue? I know its just one of your complaints, but why not… Just leave it installed?
Re Music: Plex does play music, so it does belong on the features page. Its just not as full featured a music server as say, subsonic or some others. That’s all I was
I needed to re-install it 2 times, I was testing Plex sync and after using it for 1 or 2h I'm not sure what I did but the app was crashing right away from the start so I uninstall it and re-install it but I was surprise to see all my sync content was not there anymore (it takes time to specify the video and musics..I guess I do not mind if the computer need to re-process 2 times the content as long as it save me time...I value my time to redo the sync content more)....
Will upgrading the app be the same as re-installing it, I mean will the sync content be lost? if yes then I think something need to be done so the user doesn't spend time to re-doing its sync content....
Another idea for the sync content is to either 1) have a list of what is sync on the server (that we can sync again easily, same device or another one) or to 2) press a button "backup content" before re-installing so it copied the sync content on the server and then once install we can sync/restore again (and delete the backup).....(I guess (2) is faster as it doesn't need to convert again, (1) is interesting as you can share those list on divers devices, ideally a mix or both ;))
...I'm traveling few months a year so I guess no app update while traveling otherwise the offline content is lost....
I will check subsonic, it seems to have offline playlist for music (and they seem to handle video too, I'm wondering if that works well...ah...more time to spend for testing.....c'est la vie modern....). Thanks
