Hello all,
I have married at first site AU and USA downloading. The issue I have is Plex DVR for AU downloads as “married at first site” but the none live version is “married at first site (au)”
This issue I have is now when live dvr records married at first site (au) it will move it into the USA version.
I don’t see a way to fix a live tv miss match.
Any way to fix this?
I ended up “fixing” this by changing the folder location of the AU into the USA folder. Then I made a married at first site (usa) folder, deleted AU folder, fixed the USA to match AU, and then redownloaded USA in the USA folder… working but an issue I would like PLEX to fix.
…and Sight*
Sounds like Plex doesn’t need to fix anything if you fixed your problem yourself.
The ability to fix the live tv mismatch, this is not an option, needs to be. I could fix all mismatches myself but… im not doing that lol
The matching is based on the guide details. If you create a specific library for the DVR instead of recording into your tv show library it will work correctly.
