Server Version#: 1.31.1.2262 (but happening for several versions at least)
Tuner Make/Model: HDHomerun Connect Quatro
Guide/Lineup name: UK Freeview OTA (OX25)
Using XMLTV?: no
Channel number/Name: 035 Pick TV
I have one missing episode for Stargate Atlantic (the last one of the entire series).
As it is showing again on TV, I decided to record so that I would get that last episode. However, it is trying to record everything again.
…so I am in the weird situation of living in the UK but needing to match some shows in my library using “English - United States” (instead of “English - United Kingdom”) so that new recordings will match existing shows even though those existing shows were themselves DVR’d in the UK last year.
In my experience - the DVR will show the episodes will record, but they actually won’t if you have them already - and they’re all matched to the same show. It’s a Leap of Faith. You have to find out what happened afterwards to know (or guess) what’s gonna happen in the future.
My EPG is so bad they’ll call American Experience - S01E10 ----> S54E21 (or something equally incorrect), so… yea, the DVR records those. The EPG has the NOVA episodes correct, so it doesn’t record those repeats.
Worse: The DVR adds a (YEAR) field to everything - and when matching against TVDB that doesn’t work very often. The EPG will provide the metadata, but if you’re matching (or trying to match) an existing show - they’ll be two different shows to the DVR.
The “new” episodes did record (giving me duplicates) and only stopped when I re-matched against US info. In some cases that means a different title (eg: NCIS) or not (eg: SG: Atlantis).
We have loads of “one-off” errors (so many, it must be a systematic error, of course):
Regularly, the last episode or a special will record with the date instead of season/episode so you have to go figure out what it really was (but at least it recorded).
Every now and then Plex’s EPG completely misses a show because of wrong episode/season (and you have already recorded that “wrong” one) so you’ve lost it until the repeats come round (if it comes round).
For many US shows, Plex shows the 1st two episodes as merged causing the 2nd episode to be missed and every subsequent episode to be out by 1 for the rest of that season.
Lucky for me - our transmitter (the one) was hit by lightning 7 years ago so it only works when they reboot it - On The Air: 35%, Maybe. When it’s working it broadcasts 2 viable channels.
It’s easier to fiddle with 2 channels that don’t half work - than… more than 2 channels that do work.
If you’ve been trying to get that episode for as long as I tried to get ‘The Rose Tattoo (1955)’ - I suggest you move Stargate Atlantis OUT of Plex’s View - until you have it aboard.
The Rose Tattoo was 37 years in the making…
You wouldn’t want to miss this opportunity…
Thanks for the advice. If I move it out, it will try to download every episode all again (I want the last episode of the last season only) which is over 2 months away, so I have put it in my schedule to check it the week and night before.
and in the end - The Rose Tattoo is one of Lancaster’s least liked performances. A reviewer called it ‘Wreched Overacting’ and while I would agree with that description - it’s still a pleasure to see him do it.
The first incidences appear to be linked to Plex only associating Plex’s UK EPG TV listings with library TV that has been fix-matched using “English United States” as the language.
I have no clue why the last one is happening as I tried the fix-match solution and it has made no difference. I am therefore recording episodes I don’t need to which is annoying.
