Thanks for posting, for some reason I don’t receive the notification of the new version
The auto-update wasn’t immediate - I only noticed the new version because I checked the forum this morning. I did the old reliable “google play website force update to my devices” move.
@Andrroid said:
Chapters appear to be broken again, at least if you have a preroll clip enabled.
Tested a few more movies. Some work, some don’t, same as before.
What version number are you using? If you go to settings you should see the full version number which includes build number on bottom right
6.4.0.1403
I tested some more. If I keep trying a video, it will eventually give chapters from the start of playback, but not consistently. Same as videos that seemed to work before; sometimes they show chapters, sometimes they don’t. Again, this is with using a preroll clip but no trailers.
If I add trailers into the mix, I don’t get chapters at all.
Also, in my testing of playing the movie, I found that skipping forward to the movie (past the pre roll clip) to check for chapters, can cause the app to crash.
Tonight I will disable my pre-roll clip and see what sort of consistency I can get with that.
I tested using pre-roll and trailers, and on the latest beta (6.4.0.1494) it does not display chapters. All you get is a list of the three things that have/are playing: pre-roll, trailer, and main feature. Disabled the pre-roll, still no chapters. Disabled pre-roll and trailers, and chapters appeared again. I replicated everything you found @Andrroid.
Yep, I’m tracking it, @BigWheel has created an issue and I’ll take a look when it gets scheduled. It’s possible my previous fix didn’t cover the trailer/pre-roll case, but at least I know what to look for this time so shouldn’t take as long.
