Fixing Incorrect Match
I keep having to constantly fix the incorrect match for “The Flash.” My DVR software automatically sorts series my series name and uses Plex-friendly file names, but “The Flash” keeps matching to the 1990 series instead of the current 2014 series.
I’ve used the option to fix the incorrect match multiple times, but I delete episodes as I watch them. Each time a new episode is placed in the folder named “The Flash,” Plex rematches it to the older series by that name. It seems that my only options right now are to (1) manually rename “The Flash” folder to “The Flash (2014)” every time a new episode is recorded, (2) manually fix the incorrect match from Plex for each new episode, or (3) always leave at least 1 previous episode in the folder until the new episode is recorded.
I’m not even sure if option 3 would help as I have not tried it yet. Is there any way to have Plex remember that a certain folder’s contents should always be matched to a specific series?
