For several years I’ve been noticing a bug affecting the Plex Media Server. I run the latest version on CentOS 7.
I have several music libraries full of FLAC files. PMS is configured to only use embedded Vorbis comments (no metadata lookup on the internet, no premium music library).
When a library is created, PMS will extract metadata from FLAC files during the first, initial scan. However, if the embedded Vorbis comments are later modified, PMS will not pick up the changes on further scans. Even triggering a manual metadata refresh on the whole library won’t help.
The only way to have PMS update the metadata is to move the files off the library folder, trigger a library scan to remove the items from the database, copy the items back and trigger another library scan. This is very inconvenient, especially when you have a lot of files to manage.
What can I do to help fixing this bug quickly ?
Many thanks,
Marin.
