Server Version#: 1.18.2.2058
Player Version#: 3.13.13
Vizio Model#: P65-C1
Vizio SmartCast Version#: 8.0.20.3
The Vizio app has FLAC listed under additional Direct Play Music Support, however, playback fails to start when using the Vizio Plex app. I’m experiencing the same issue on local and remote servers. From the logs, it appears the client is disconnecting:
Dec 15, 2019 20:02:24.686 [8188] DEBUG - Failed to stream media, client probably disconnected after 1523712 bytes: 10054 - An existing connection was forcibly closed by the remote host
Dec 15, 2019 20:02:24.686 [8188] DEBUG - Completed after connection close: [IP Redacted] 206 GET /library/parts/98449/1576296484/file.flac (8 live) TLS 139ms 1523712 bytes (pipelined: 10) (range: bytes=0-)
When playback is initiated from the iOS app and cast to the TV, it works without issue.
Is this a client bug? A configuration issue on my part?
