Is it possible to install flex TV with an Nvidia shield running as your server ? Tia
I assume you mean Plex. The answer is yes. A Plex server comes pre-installed on the Shield and all it needs is to be activated and set up. I ran a Plex server on my Shield for quite a while and found it a good solid implementation.
No I mean flex TV , it’s a plugin that allows you to integrate with Google assistant so you can ask it to play from Plex
Then I really cannot help as I have never dealt with such an implementation. Sorry.
