Folder view gone on SHIELD, again
Server Version#:
Today the “folder view” went missing om my Nvidia Shield Plex. It is impossible to find episodes without it. Anyone else with the same problem? Any solution?
I cannot comment on the missing folder view… but how is it impossible to find your episodes without it?
If I for example have a couple of hundreds of tv-series and the names or tags are not entirely correct, nothing shows up sorted or in order so I have to look everything to find the right episode.
Thank you for pointing this out, thought I was going insane and restarting server and shield several times without browse by folder showing up. It did work yesterday!! But ofcourse a update today removed it.
I can’t find anything anymore and with 30tb+++ I don’t have the luxury to use metadata.
So now I have to use my phone and cast to the Chromecast instead.
And now it is gone again after it was back yesterday?!?!? What the heck are you doing? I am trying to binge watch some old series but now i can’t find the folders (((
I found the problem.
It is not the updates themself, it is when it is upgrading the plex app on the shield it happend.
So if i uninstall updates and reinstall the folders are back. This i have to do with each update on the shield.
I’m just going to tag on here instead of creating a new thread, I guess.
The loss of folder functionality on the new Plex app (Uno, I guess?) is a dealbreaker; on both Fire TV and Nvidia Shield.
Now, I’ve always thought all the added little “features” were annoying, but that’s personal preference (you’re “suggesting” what I should watch from my own library?), and the removal of real FF/rew in favor of skipping only, also annoying (usually I use Kodi, which has, you know, options).
But the removal of folder view (or, the release of this app before you’ve implemented it), makes it unusable (literally).
I mean, I’m just downgrading it, but please STOP with these “improvements”. I’m not going to go on about the various home movies and other files that I MUST organize ONLY in folders - the Plex team knows that, but you’re abandoning us in favor of some weird “smart” UI. Bring back the grace of the Plex Home Theater :heart::orange_heart::yellow_heart::orange_heart::heart:
edit: I see the reply from BigWheel showing where the folders are - those options definitely weren’t there before I reverted (of course I checked through every option in every version of every menu before spending awhile reverting) - will check again some time in the future.
It’s not gone. It is in the same relative menu as in the web app
TV library Web app
TV library Android TV
movie library web app
movie library, Android TV
