For me jas
Server Version#:
<If providing server logs please do NOT turn on verbose logging, only debug logging should be enabled># -- coding: utf-8 --
import os
import shutil
import io
import fnmatch
import re
import base64
import json
import urllib
import time
from datetime import datetime
from io import StringIO
from lxml import etree
element_from_string = XML.ElementFromString
load_file = Core.storage.load
PREFIX = ‘/video/AdultScraperX’
NAME = ‘AdultScraperX Beta1.6.3’
ART = ‘art-default.jpg’
ICON = ‘icon-default.png’
PMS_URL = ‘http://127.0.0.1:32400/library/sections/’
HTTP
timeout = 3600
def Start():
HTTP.CacheTime = 0
class AdultScraperXAgent(Agent.Movies):
name = NAME
languages = [Locale.Language.English]
primary_provider = True
accepts_from = [
‘com.plexapp.agents.localmedia’,
‘com.plexapp.agents.opensubtitles’,
‘com.plexapp.agents.podnapisi’,
‘com.plexapp.agents.subzero’
contributes_to = [
‘com.plexapp.agents.themoviedb’,
‘com.plexapp.agents.imdb’,
‘com.plexapp.agents.data18’
def search(self, results, media, lang, manual):
    # 源文件路径
    msrcfilepath = os.path.join('/'.join(media.items[0].parts[0].file.split('/')[
                                0:len(media.items[0].parts[0].file.split('/'))-1]))
    Log('源文件路径:%s' % msrcfilepath)
    nfopath = self.searchFilesPath(msrcfilepath, '.nfo')
    Log(nfopath)
    # 海报剪切微调
    :param r: 横向裁切位置
    :param w: 缩放比例:宽
    :param h: 缩放比例:高
    pcft = {}
    r = 0
    w = 0
    h = 0
    if len(re.findall('--pcft', media.name)) > 0:
        Log('海报微调模式:开启')
        tmps = media.name.split('--pcft')
        tmp = tmps[1].split(',')
        for index, rwh in enumerate(range(len(tmp))):
            res = re.findall(r'\d[0-9]{0,}', tmp[index].replace(' ',''))
            if len(res)>0:
                if index == 0:
                    r = res[0]
                if index == 1:
                    w = res[0]
                if index == 2:
                    h = res[0]
        media.name = tmps[0]
        pcft.update({'r':r,'w':w,'h':h})
        Log('\n横向裁切位置r: %s\n缩放比例:宽w: %s\n缩放比例:高h: %s\n参数0为默认执行' % (r, w, h))
    else:
        Log('海报微调模式:关闭')
        #Log('\n横向裁切位置r: %s\n缩放比例:宽w: %s\n缩放比例:高h: %s\n参数0为默认执行' % (r, w, h))
    if len(re.findall('--checkState', media.name)) > 0 or len(re.findall('--checkSpider', media.name)) > 0 or len(re.findall('--nore', media.name)) > 0:
        Log('命令模式:开启')
        #self.searchLocalMediaNFO(results, media, lang, manual, nfopath)
        self.searchOnlineMediaInfo(results, media, lang, manual,pcft)
    else:
        if len(nfopath) > 0:
            Log('查询模式:local')
            if not self.searchLocalMediaNFO(results, media, lang, manual, nfopath):
        else:
            Log('查询模式:Online')
def assrtDownSubTitle(self, number, path):
    # 射手
    assrt_domain = 'https://assrt.net'
    assrt_search_url = assrt_domain+'/sub/?searchword='+number
    assrt_down_url = assrt_domain+'/download/****/-/**/*.*'
    assrt_diteall_paths = ''
    c = 0
    try:
        # 搜索字幕
        HTTP.ClearCache()
        HTTP.CacheTime = CACHE_1MONTH
        assrt_result = HTTP.Request(
            assrt_search_url, timeout=timeout).content
        rep_html = '<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">'
        assrt_result = assrt_result.replace(rep_html, '')
        rep_html = '<html xmlns:wb="http://open.weibo.com/wb" lang="zh-CN"><head><meta http-equiv="Content-Type" content="text/html; charset=UTF-8">'
        assrt_result = assrt_result.replace(rep_html, '<html>')
        rep_html = r'<!--<base href="/search2/%E7%94%9F%E6%B4%BB%E5%A4%A7%E7%88%86%E7%82%B8/">-->'
        assrt_diteall_paths = etree.HTML(assrt_result).xpath(
            '//div[@class="sublist_box_title"]//a/@href')
    except Exception as ex:
        Log(ex)
        return c
    if len(assrt_diteall_paths) > 0:
        Log('在assrt匹配到字幕:%s' % number)
        try:
            assrt_id = assrt_diteall_paths[0].split(
                '/')[len(assrt_diteall_paths[0].split('/'))-1].split('.')[0]
            Log('assrt 字幕id:%s' % assrt_id)
            HTTP.ClearCache()
                assrt_domain+assrt_diteall_paths[0], timeout=timeout).content
            assrt_file_paths = etree.HTML(assrt_result).xpath(
                '//div[@class="waves-effect"]/@onclick')
            if len(assrt_file_paths) > 0:
                art_download_count = 1
                for files in assrt_file_paths:
                    try:
                        tmps = files.replace('onthefly(', '').replace(
                            '"', '').replace(')', '').split(',')
                        houzhui = tmps[2].split('.')[1]
                        if houzhui == 'ass' or houzhui == 'ssa' or houzhui == 'srt' or houzhui == 'sub' or houzhui == 'smi' or houzhui == 'idx' or houzhui == 'smi' or houzhui == 'psg':
                            assrt_down_url = assrt_down_url.replace(
                                '****', tmps[0]).replace('**', tmps[1]).replace('*.*', tmps[2])
                            HTTP.ClearCache()
                                assrt_down_url, timeout=timeout).content
                            subtitle_path = os.path.join(
                                path+'/'+number+'.'+tmps[2].split('.')[1])
                            if os.path.exists(subtitle_path):
                                tmps = number+'.'+datetime.now().strftime('%Y-%m-%d %H:%M:%S').replace(
                                    '-', '').replace(':', '').replace(' ', '')+'.'+tmps[2].split('.')[1]
                                subtitle_path = os.path.join(path+'/'+tmps)
                            fo = io.open(subtitle_path, "w",
                                         encoding='utf-8')
                            fo.write(u''+assrt_result)
                            fo.close()
                            if os.path.getsize(subtitle_path) > 1:
                                Log('字幕 %s 下载完成' % tmps[2].split('.')[0])
                                c = c+1
                                break
                            elif art_download_count == int(Prefs['Cycles']):
                                Log('字幕 %s 下载失败' % tmps[2].split('.')[0])
                                break
                            else:
                                art_download_count = int(
                                    art_download_count+1)
                        else:
                            break
                        Log(ex)
                        return c
            Log(ex)
            return c
        return c
    return c
def searchLocalMediaNFO(self, results, media, lang, manual, nfopath):
    data = {
        "m_studio": "",
        "m_id": "",
        "m_actor": {},
        "m_directors": "",
        "m_summary": "",
        "m_collections": "",
        "m_number": "",
        "m_title": "",
        "m_category": "",
        "m_art_url": "",
        "m_originallyAvailableAt": "",
        "m_year": "",
        "m_poster": ""
    nfo_file = nfopath[0]
    NFO_TEXT_REGEX_1 = re.compile(
        r'&(?![A-Za-z]+[0-9]*;|#[0-9]+;|#x[0-9a-fA-F]+;)'
    NFO_TEXT_REGEX_2 = re.compile(r'^\s*<.*/>[\r\n]+', flags=re.MULTILINE)
    RATING_REGEX_1 = re.compile(
        r'(?:Rated\s)?(?P<mpaa>[A-z0-9-+/.]+(?:\s[0-9]+[A-z]?)?)?'
    RATING_REGEX_2 = re.compile(r'\s*\(.*?\)')
    nfo_text = load_file(nfo_file)
    nfo_text = NFO_TEXT_REGEX_1.sub('&amp;', nfo_text)
    nfo_text = NFO_TEXT_REGEX_2.sub('', nfo_text)
    nfo_text_lower = nfo_text.lower()
    if nfo_text_lower.count('<movie') > 0 and nfo_text_lower.count('</movie>') > 0:
        nfo_text = '{content}</movie>'.format(
            content=nfo_text.rsplit('</movie>', 1)[0]
        # likely an xbmc nfo file
        try:
            nfo_xml = element_from_string(nfo_text).xpath('//movie')[0]
            Log(ex)
            return False
        # number
        try:
            data.update({'m_number': nfo_xml.xpath('number')[0].text})
            Log('NFO number : %s' % ex)
            return False
        # Title
        try:
            data.update({'m_title': nfo_xml.xpath('title')[0].text})
            Log('NFO Title : %s' % ex)
            return False
        # original_title
        try:
            data.update(
                {'original_title': nfo_xml.xpath('originaltitle')[0].text})
            Log('NFO original_title : %s' % ex)
            return False
        # summary
        try:
            data.update({'m_summary': nfo_xml.xpath('outline')[0].text})
            Log('NFO summary : %s' % ex)
            return False
        # year
        try:
            data.update({'m_year': nfo_xml.xpath('year')[0].text})
            Log('NFO year : %s' % ex)
            return False
        # originallyAvailableAt
        try:
            data.update(
                {'m_originallyAvailableAt': nfo_xml.xpath('premiered')[0].text})
            Log('NFO originallyAvailableAt : %s' % ex)
            return False
        # category
        try:
            categorys = []
            for citem in nfo_xml.xpath('genre'):
                categorys.append(citem.text)
            if categorys[0] == None:
                categorys = ''
            data.update({'m_category': ','.join(categorys)})
            Log('NFO category : %s' % ex)
            return False
        # director
        try:
            data.update({'m_directors': nfo_xml.xpath('director')[0].text})
            Log('director : %s' % ex)
            return False
        # collections
        try:
            collections = []
            for colitem in nfo_xml.xpath('collections'):
                if isinstance(colitem, list):
                    collections.append(colitem[0].text)
                else:
                    coltmp = colitem.text
                    collections.append(coltmp)
            if len(collections) < 1:
                collections = ''
            data.update({'m_collections': collections})
            Log('NFO collections : %s' % ex)
            return False
        # poster
        try:
            data.update({'m_poster': nfo_xml.xpath('thumb')[0].text})
            Log('poster : %s' % ex)
            return False
        # actor
        actors = nfo_xml.xpath('actor')
        items = {}
        try:
            for actor in actors:
                if len(actor.xpath('thumb')) > 0:
                    items.update(
                        {actor.xpath('name')[0].text: actor.xpath('thumb')[0].text})
                else:
                    items.update(
                        {actor.xpath('name')[0].text: ''})
            data.update({'m_actor': items})
            Log('NFO actor : %s' % ex)
            return False
        # dirTagLine
        try:
            data.update(
                {'dirtagline': nfo_xml.xpath('dirtagline')[0].text})
            Log('NFO dirTagLine : %s' % ex)
            return False
        data.update(
            {'r':0,'w':0,'h':0}
        jsondata = json.dumps(data)
        Log('查询结果数据:%s' % jsondata)
        id = data['m_number']
        wk = 'NFO'
        name = '%s : %s' % (wk, data['m_title'])
        media_d = jsondata
        dirTagLine = data['dirtagline']
        id = base64.b64encode('%s|A|%s|%s|%s' % (
            id, wk, media_d, dirTagLine))
        score = 100
        new_result = dict(id=id, name=name,
                          year='', score=score, lang=lang)
        results.Append(MetadataSearchResult(**new_result))
        Log('匹配数据结果:%s 【success】' % data['m_number'])
        return True
    else:
        return False
def searchOnlineMediaInfo(self, results, media, lang, manual,pcft):
    Log('======开始查询======')
    # 获取path
    dirTagLine = None
    filePath = media.items[0].parts[0].file
    mediaPath = String.Unquote(filePath, usePlus=False)
    Log('本地文件路径:%s' % filePath)
    mediaPathSplitItems = mediaPath.split('/')
    for item in mediaPathSplitItems:
        # 正则判断是否匹配 有结果就给出
        tmp = re.findall(Prefs['Dir_M'], item)
        if len(tmp) == 1:
            dirTagLine = 'censored'
            break
        tmp = re.findall(Prefs['Dir_NM'], item)
        if len(tmp) == 1:
            dirTagLine = 'uncensored'
            break
        tmp = re.findall(Prefs['Dir_A'], item)
        if len(tmp) == 1:
            dirTagLine = 'animation'
            break
        tmp = re.findall(Prefs['Dir_E'], item)
        if len(tmp) == 1:
            dirTagLine = 'europe'
            break
    Log("本地文件判别类型标记:%s" % dirTagLine)
    if dirTagLine != None:
        if manual:
            LocalFileName = media.name
            queryname = base64.b64encode(LocalFileName).replace('/', '[s]')
            Log('手动匹配Plex输出文件名:%s' % media.name)
            Log('格式化后文件名:%s' % LocalFileName)
            Log('base64后的关键字:%s' % queryname)
            Log('执行模式:手动')
            HTTP.ClearCache()
            jsondata = HTTP.Request('%s:%s/manual/%s/%s/%s/%s/%s' % (Prefs['Service_IP'], Prefs['Service_Port'], dirTagLine,
        queryname, Prefs['Service_Token'], Prefs['User_DDNS'], Prefs['Plex_Port']), timeout=timeout).content
            dict_data_list = json.loads(jsondata)
            if dict_data_list['issuccess'] == 'true':
                json_data_list = dict_data_list['json_data']
                if Prefs['Orderby'] == '反序':
                    Log('结果输出排序方式:反序')
                elif Prefs['Orderby'] == '默认':
                    Log('结果输出排序方式:默认')
                    json_data_list.reverse()
                for json_data in json_data_list:
                    for data_list_key in json_data:
                        id = ''
                        name = ''
                        media_d = ''
                        wk = data_list_key
                        data = json_data.get(data_list_key)
                        data.update(pcft)# 微调海报参数
                        Log(pcft)
                        data.update(original_title='')
                        for item_key in data:
                            if item_key == 'm_number':
                                id = data.get(item_key)
                            if item_key == 'm_title':
                                data['original_title'] = data['m_title']
                                poster_url = data['m_poster']
                                poster_data = {
                                    'mode': 'poster',
                                    'url': poster_url,
                                    'webkey': wk.lower()
                                poster_data_json = json.dumps(poster_data)
                                url = '%s:%s/img/%s/%s/%s/%s' % (
                                    Prefs['Service_IP'], Prefs['Service_Port'], base64.b64encode(poster_data_json),pcft['r'],pcft['w'],pcft['h'])
                                thumb = url
                                name = '%s: %s %s' % (
                                    wk, data['m_number'], data.get(item_key))
                        data_d = json.dumps(data)
                            '%s|M|%s|%s|%s' % (id, wk, data_d, dirTagLine))
                        score = 100
                        new_result = dict(
                            id=id, name=name, year='', score=score, lang=lang, thumb=thumb)
                        results.Append(
                Log('匹配数据结果:%s 【success】' % LocalFileName)
            else:
                Log('匹配数据结果:%s 【无】' % LocalFileName)
        else:
            LocalFileName = self.getMediaLocalFileName(media)
            Log('本地文件名:%s' % LocalFileName)
            Log('模式:自动')
            HTTP.ClearCache()
            jsondata = HTTP.Request('%s:%s/auto/%s/%s/%s/%s/%s' % (Prefs['Service_IP'], Prefs['Service_Port'], dirTagLine,
            dict_data = json.loads(jsondata)
            if dict_data['issuccess'] == 'true':
                data_list = dict_data['json_data']
                data_list.reverse()
                for data in data_list:
                    id = ''
                    name = ''
                    media_d = ''
                    wk = data
                    for webkey in data:
                        media_dict = data.get(webkey)
                        wk = webkey
                        media_dict.update(original_title='')
                        for item_key in media_dict:
                                id = media_dict.get(item_key)
                                media_dict['original_title'] = media_dict.get(
                                    item_key)
                                name = media_dict.get(item_key)
                        media_dict.update(pcft)# 微调海报参数
                        media_d = json.dumps(media_dict)
                    score = 100
            else:
    Log('======结束查询======')
def update(self, metadata, media, lang):
    Log('======开始执行更新媒体信息======')
    metadata_list = base64.b64decode(metadata.id).split('|')
    m_id = metadata_list[0]
    Log('解析base64传递数据-番号:%s' % m_id)
    manual = metadata_list[1]
    Log('解析base64传递数据-执行模式:%s' % manual)
    webkey = metadata_list[2]
    Log('解析base64传递数据-元数据站点:%s' % webkey)
    data = metadata_list[3]
    Log('解析base64传递数据-更新数据:%s' % data)
    data = json.loads(data)
    dirTagLine = metadata_list[4]
    Log('解析base64传递数据-文件类型判别标记:%s' % dirTagLine)
    # 微调参数
    try:
        r = data['r']
        r = 0
    try:
        w = data['w']
        w = 0
    try:
        h = data['h']
        h = 0
    '在标语处显示来源元数据站点'
    metadata.tagline = webkey
    number = ''
    poster = None
    art = None
    for i, media_item in enumerate(data):
        if media_item == 'm_number':
            number = data.get(media_item)
            if dirTagLine == 'europe':
                Log('标题模式:欧美')
                metadata.title = data['m_title']
            else:
                Log('标题模式:日本')
                if number == '':
                else:
                    if webkey == 'ArzonAnime':
                        if Prefs['Title_jp_anime'] == '番号':
                            metadata.title = number
                        elif Prefs['Title_jp_anime'] == '标题':
                            if Prefs['Trantitle'] == '开启':
                                Log("标题翻译:开启")
                                HTTP.ClearCache()
                                tran_url = '%s:%s/t/%s/%s' % (Prefs['Service_IP'], Prefs['Service_Port'], dirTagLine, base64.b64encode(
                                    data['m_title']).replace('/', ';<*'))
                                if not data['m_title'] == '':
                                    Log('翻译连接:%s', tran_url)
                                    tran_title = HTTP.Request(
                                        tran_url, timeout=timeout).content
                                    metadata.title = tran_title
                                else:
                            else:
                        elif Prefs['Title_jp_anime'] == '番号,标题':
                                Log("标题翻译:开启")
                                HTTP.ClearCache()
                                    metadata.title = '%s %s' % (
                                        number, tran_title)
                                else:
                                        number, data['m_title'])
                            else:
                    else:
                        if Prefs['Title_jp'] == '番号':
                        elif Prefs['Title_jp'] == '标题':
                                Log("标题翻译:开启")
                                HTTP.ClearCache()
                                else:
                            else:
                        elif Prefs['Title_jp'] == '番号,标题':
                                Log("标题翻译:开启")
                                HTTP.ClearCache()
                                        number, tran_title)
                                else:
                            else:
        if media_item == 'original_title':
            metadata.original_title = data.get(media_item)
        if media_item == 'm_summary':
            if Prefs['Transum'] == '开启':
                if data.get(media_item) == '' or data.get(media_item) == None:
                    metadata.summary = data.get(media_item)
                else:
                    Log("简介翻译:开启")
                    HTTP.ClearCache()
                                                  dirTagLine, base64.b64encode(data.get(media_item)).replace('/', ';<*'))
                    tran_summary = HTTP.Request(
                    metadata.summary = tran_summary
            else:
        if media_item == 'm_studio':
            metadata.studio = data.get(media_item)
        if media_item == 'm_collections':
            metadata.collections.clear()
            mediaPathSplitItems = msrcfilepath.split('/')
            tmp = ''
                if len(re.findall(Prefs['Dir_C'], item)) > 0:
                    tmp = item
            if len(tmp) > 0:
                tmp = tmp.replace(Prefs['Dir_C'], '')
                Log('检测到合集标志并以 %s 作为合集名' % tmp)
                metadata.collections.add(tmp)
            else:
                if not data.get(media_item) == '':
                    if isinstance(data.get(media_item), list):
                        metadata.collections.add(data.get(media_item)[0])
                    else:
                            data.get(media_item).encode("UTF-8"))
                else:
                    metadata.collections.add('')
        if media_item == 'm_originallyAvailableAt':
            try:
                    date_object = datetime.strptime(
                        data.get(media_item).replace('/', '-'), r'%Y-%m-%d')
                    metadata.originally_available_at = date_object
                    Log('上映日期:%s' % date_object)
                else:
                    metadata.originally_available_at = datetime.strptime(
                        '1900-01-01', r'%Y-%m-%d')
                Log('上映日期:捕获异常:%s', ex)
        if media_item == 'm_year':
            try:
                metadata.year = int(
                    data.get(media_item).replace('/', '-').split('-')[0])
                Log('影片年份:%s' % data.get(media_item).replace(
                Log('影片年份:%s 捕获异常:%s' % (data.get(media_item), ex))
        if media_item == 'm_directors':
            metadata.directors.clear()
            metadata.directors.new().name = data.get(media_item)
        if media_item == 'm_category':
            metadata.genres.clear()
            genres_list = data.get(media_item).split(',')
            for genres_name in genres_list:
                metadata.genres.add(genres_name)
        if media_item == 'm_poster':
            if webkey == 'NFO':
                try:
                    posterpath = self.searchFilesPath(
                        msrcfilepath, '-poster.jpg')
                    if posterpath.count>0:
                        posterpath=posterpath[0]
                        metadata.posters[posterpath] = Proxy.Media(
                            load_file(posterpath))
                    Log('NFO海报 : 捕获异常:%s:%s' % (ex, posterpath))
            else:
                try:
                    poster_url = data.get(media_item)
                    poster_data = {
                        'mode': 'poster',
                        'url': poster_url,
                        'webkey': webkey.lower()
                    purl = '%s:%s/img/%s/%s/%s/%s' % (Prefs['Service_IP'],
                                            Prefs['Service_Port'], base64.b64encode(poster_data_json),r,w,h)
                    Log('海报:%s' % purl)
                    poster = HTTP.Request(purl, timeout=timeout).content
                    Log('海报捕获异常:%s:%s' % (ex, purl))
                if not poster == None:
                    metadata.posters[purl] = Proxy.Media(poster)
        if media_item == 'm_art_url':
            if webkey == 'NFO':
                try:
                    artpath = self.searchFilesPath(msrcfilepath, '-fanart.jpg')
                    if artpath.count>0:
                        artpath=artpath[0]
                        metadata.art[artpath] = Proxy.Media(
                            load_file(artpath))
                    Log('NFO背景 : 捕获异常:%s:%s' % (ex, artpath))
            else:
                try:
                    art_url = data.get(media_item)
                    art_data = {
                        'mode': 'art',
                        'url': art_url,
                    art_data_json = json.dumps(art_data)
                    aurl = '%s:%s/img/%s/%s/%s/%s' % (Prefs['Service_IP'],
                                            Prefs['Service_Port'], base64.b64encode(art_data_json),r,w,h)
                    Log('背景:%s' % aurl)
                    art = HTTP.Request(aurl, timeout=timeout).content
                    Log('背景捕获异常:%s:%s' % (ex, aurl))
                if not art == None:
                    metadata.art[aurl] = Proxy.Media(art)
        if media_item == 'm_actor':
            metadata.roles.clear()
            actors_list = data.get(media_item)
            if actors_list != '':
                for key in actors_list:
                    role = metadata.roles.new()
                    role.name = key
                    imgurl = actors_list.get(key)
                    if imgurl != '':
                        art_data = {
                            'mode': 'actor',
                            'url': imgurl,
                        if webkey == 'NFO':
                            url = imgurl
                        else:
                            Log('演员 %s 头像:%s' % (role.name, url))
                        role.photo = url
                    else:
                        role.photo = ''
    # 设置影片级别
    metadata.content_rating = 'R18'
    # 下载字幕
    if Prefs['SubtitleDown'] == '开启':
        dcount = self.assrtDownSubTitle(number, msrcfilepath)
        if dcount > 0:
            Log('匹配到字幕并下载完成 %s 个' % dcount)
    if not webkey == 'NFO':
        if Prefs['BKNFO'] == '开启':
            if not dirTagLine == 'europe':
                self.createNFO(metadata, media, number, poster,
                            purl, art, aurl, dirTagLine)
    Log('更新媒体信息 :【%s】 结束' % m_id)
    Log('======结束执行更新媒体信息======')
def createNFO(self, metadata, media, number, poster, purl, art, aurl, dirtagline):
    Log('开始生成NFO文件,海报 , 演员图片')
    xml = '<?xml version="1.0" encoding="UTF-8" standalone="yes"?>\n'
    xml = xml + '<movie>\n'
    # dirtagline
    xml = xml + '<dirtagline>%s</dirtagline>\n' % dirtagline
    # number
    xml = xml + '<number>%s</number>\n' % number
    # 标题
    xml = xml + '<title>%s</title>\n' % metadata.title
    xml = xml + '<originaltitle>%s</originaltitle>\n' % metadata.original_title
    # 简介
    xml = xml + '<outline>%s</outline>\n' % metadata.summary
    # 标语
    xml = xml+'<tagline>%s</tagline>\n' % metadata.tagline
    # 影片年份
    xml = xml + '<year>%s</year>\n' % metadata.year
    # 上映日期
    xml = xml+'<premiered>%s</premiered>\n' % metadata.originally_available_at
    # 级别
    xml = xml+'<mpaa>R18</mpaa>\n'
    # 类型
    for genre in metadata.genres:
        xml = xml + '<genre>%s</genre>\n' % genre
    # 工作室
    '<studio>%s</studio>\n' % metadata.studio
    # 导演
    for director in metadata.directors:
        xml = xml + '<director>%s</director>\n' % director.name
    # 系列
    for collections in metadata.collections:
        if not collections == None or collections == '':
            xml = xml+'<collections>%s</collections>\n' % collections
    # 同名目录没有则创建
    # src文件名拆分
    filepathlist = media.items[0].parts[0].file.split('/')
    Log('src文件名拆分:%s' % filepathlist)
    # 文件名+后缀
    filenameall = filepathlist[len(filepathlist)-1]
    Log('文件名+后缀:%s' % filenameall)
    # 文件名
    filename = filenameall.split('.')[0]
    Log('文件名:%s' % filename)
    # 原文件全路径
    srcfilepath = os.path.join(media.items[0].parts[0].file)
    Log('原文件全路径: %s' % srcfilepath)
    # 新文件路径
    ftmp = srcfilepath.replace('/'+filenameall, '').replace('/'+number, '')
    newfilepath = ftmp+'/'+number
    Log('新文件路径:%s' % newfilepath)
    if not os.path.exists(newfilepath):
        try:
            os.makedirs(newfilepath)
            Log('创建 %s 目录:%s' % (number, newfilepath))
            Log('创建目录发生异常:%s \r\n %s ' % (newfilepath, ex))
