For some reason When I add each season individually of a TV show On Plex it works But not when I add a TV show folder With all the seasons in it on Plex It does not seem to pick it up
You’re not giving us much to go on.
Can you post an actual as-you-have-it example?
What OS?
I bet you have one folder level too much or one too few.
Take a look at your tv show library properties.
At the tab ‘Add Folders’, which path(s) are listed in there? (maybe make a screenshot)
Then I need the exact folder and file names of this tv show as well.
here is a screen shot
F:\TV Shows is the folder you should add. Remove the individuals.
@ChuckPA said:
F:\TV Showsis the folder you should add. Remove the individuals.
Precisely.
