Hi All, … Here is my set up, I have an Nexus Player connected to my Phillips TV, Over HDMI. Now i currently have passthrough enabled on the TV to pass all audio down the Toslink Cable to my Sonos PlayBar. Now as many of you are going to say Sonos does not play DTS audio this im aware of hence the question. Now a lot of my content is DTS Audio, and when i have plex set to passthrough “auto” it passes DTS auto to my sonos bar which doesnt work unless its anything else it works PERFECT. If i select disable it tells plex to transcode audio but always does so into stereo. So. i would like to no is it possible to force a DTS transcode to DD or AC3 with 5.1, or if possible even more
… only apply DTS transcode to DD or AC3 if played off android tv
… (So in a nutshell is anyone aware of a .xml file i may have able to edit that says if client is (Nexus Player) remove the DTS support,
… So it doesnt try and send it me in the first place and the server does all the work…
OS Ubuntu
