Found only 4 channels (DVB-C Hungary)
I wanted to try our DVR in Plex (using Tvheadend all the time).
I have an unencrypted DVB-C broadcast over cable in Hungary (Digi Hungary provider). For some odd reason, Plex is only able to find 4 channels. Did several attempts to scan, nothing.
I looked at the 5161.ini file, that should be for my provider, but it is not up to date. Even if some freq has changed, it should have found more. I tried an updated list, nothing.
I load the xml too, but it doesn’t really matter yet, as there are no channels, except the 4.
Btw, those four channels play nice.
Plex Media Server Logs_2021-11-17_13-34-08.zip (513.8 KB)
Tunner is Hauppauge WinTV-DualHD DVB-C, working perfectly fine in Tvheadend.
Logs attached. Your help is much appreciated.
