Having a strange issue under the AGENTS, -> MOVIES -> FREEBASE where no matter what order i put anything in or check to enable it resets when the menu is changed or moved aware from. ONLY the grayed out FREEBASE remains active.
It saves any settings inside the agent that have been set, but the preference order and check to enable is always reset back to the original order and no longer checked.
Any ideas?
