Agent selection and order not being saved
I just installed Sub-zero for better subtitle download and handling, and this is the first time I’ve mucked with Plex Agents. I’m finding that my selection for which agents are enabled and what order they are in, are not saving consistently. Sometimes Sub-zero will be saved as selected, then when I try to add FanArt.tv, everything unselects if I navigate away and come back.
Not sure if it’s related at all, but I’m also seeing 404s for 2 agents (opensubtitles and local media) but since I wasn’t sure, I posted that in a separate thread: https://forums.plex.tv/discussion/222181/getting-404s-on-2-agents-opensubtitles-and-local-media/
Any idea what’s going on?
Just found the answer… seems like there is a bug with FF and Chrome. Using IE and it worked!
Credit goes to this thread: https://forums.plex.tv/discussion/219307/my-plex-agent-options-are-not-saving
