Agent settings self-selection issue.
Open Media Manager’s Agent setting window and select the Freebase metadata plugin in the left pane. On the right hand side, we should be able to see plugins that contribute to Freebase in a specific order. So, in the right pane, I see that Freebase is preselected. It’s impossible to unselect (uncheck) this plugin in the right pane, which is what you’d expect - Freebase contributes to itself, period.
Custom plugins do not have this behavior. How do I
  1. make my plugin to be preselected;
  2. specify the order of other contributing plugins (if it’s even possible).
    Take a look at the second screenshot where I have selected a non-supported (KinoPoiskRu) metadata plugin. How do I make this plugin to be preselected? I couldn’t find anything in the Freebase source code that does it. Am I missing something?
Anyone? Any idea? :slight_smile:
