Server Version#: 1.40.3
Tried to claim using generated token, as well as manual token. Error claiming.
Normal claiming using oauth dialog goes through, but the server isn’t actually claimed.
It seems PMS can’t actually reach plex.tv due to an SSL issue.
The issue is not with my server, nor is it with the docker container.
I tried doing everything from scratch and it still didn’t work.
Grabbing a URL from the log, going inside the plex container and running
curl "https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.40.3.8555-fef15d30c"
Works just fine.
I tried using the linuxserver container as well as the official container.
Jul 09, 2024 16:34:13.147 [23188626729784] Warning — [HttpClient/HCl#1a] HTTP error requesting POST https://plex.tv/api/claim/exchange?token=xxxxxxxxxxxxxxxxxxxxZgiYRK (35, SSL connect error) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:13.171 [23188626729784] Warning — [HttpClient/HCl#1c] HTTP error requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxror) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:13.171 [23188615838520] Warning — [Req#122] [Analytics] Couldn't get analytics privacy settings. Trying again soon.
Jul 09, 2024 16:34:13.193 [23188626729784] Warning — [HttpClient/HCl#1d] HTTP error requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxror) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:13.193 [23188615838520] Warning — [Req#122] [AutoUpdateRequestHandler] Couldn't get update channels. Trying again soon.
Jul 09, 2024 16:34:13.216 [23188626729784] Warning — [HttpClient/HCl#1e] HTTP error requesting GET https://plex.tv/api/v2/features?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxror) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:13.216 [23188615838520] Warning — [Req#122] FeatureManager: Couldn't get features. Trying again soon.
Jul 09, 2024 16:34:21.483 [23188617947960] Warning — [Req#16a] [Preferences] No update channels loaded, so showing the previously-selected channel, labelled 'unknown' since we don't really know the name.
Jul 09, 2024 16:34:30.325 [23188617947960] Warning — [Req#184] [Preferences] No update channels loaded, so showing the previously-selected channel, labelled 'unknown' since we don't really know the name.
Jul 09, 2024 16:34:49.452 [23188615838520] Warning — [Req#1c8] [Preferences] No update channels loaded, so showing the previously-selected channel, labelled 'unknown' since we don't really know the name.
Jul 09, 2024 16:34:57.099 [23188603181880] Warning — [Req#349] [Preferences] No update channels loaded, so showing the previously-selected channel, labelled 'unknown' since we don't really know the name.
Jul 09, 2024 16:34:57.149 [23188626729784] Warning — [HttpClient/HCl#1f] HTTP error requesting GET https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.40.3.8555-fef15d30c (35, SSL connect error) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:57.149 [23188556151608] Error — [Req#391] HTTP -35 downloading url https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.40.3.8555-fef15d30c
Jul 09, 2024 16:34:57.149 [23188617947960] Info — [Req#391] AutoUpdate: error getting data from plex.tv
Jul 09, 2024 16:34:58.169 [23188626729784] Warning — [HttpClient/HCl#20] HTTP error requesting GET https://plex.tv/users/27a685f3860efb48/avatar?c=1720552924&size=100 (35, SSL connect error) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:58.169 [23188626729784] Warning — [HttpClient/HCl#21] HTTP error requesting GET https://plex.tv/users/27a685f3860efb48/avatar?c=1720552924&size=150 (35, SSL connect error) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:58.247 [23188626729784] Warning — [HttpClient/HCl#22] HTTP error requesting GET https://plex.tv/users/fbace6cc4db534b3/avatar?c=1714470453&size=100 (35, SSL connect error) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:58.247 [23188626729784] Warning — [HttpClient/HCl#23] HTTP error requesting GET https://plex.tv/users/fbace6cc4db534b3/avatar?c=1714470453&size=150 (35, SSL connect error) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:58.247 [23188626729784] Warning — [HttpClient/HCl#24] HTTP error requesting GET https://plex.tv/users/a37f18018b2b0956/avatar?c=1720206602&size=100 (35, SSL connect error) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:34:58.247 [23188626729784] Warning — [HttpClient/HCl#25] HTTP error requesting GET https://plex.tv/users/a37f18018b2b0956/avatar?c=1720206602&size=150 (35, SSL connect error) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:35:00.198 [23188615838520] Warning — [Req#495] [Preferences] No update channels loaded, so showing the previously-selected channel, labelled 'unknown' since we don't really know the name.
Jul 09, 2024 16:35:00.248 [23188626729784] Warning — [HttpClient/HCl#26] HTTP error requesting GET https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.40.3.8555-fef15d30c (35, SSL connect error) (OpenSSL/3.1.1: error:0A000458:SSL routines::tlsv1 unrecognized name)
Jul 09, 2024 16:35:00.248 [23188554042168] Error — [Req#4c1] HTTP -35 downloading url https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.40.3.8555-fef15d30c
Jul 09, 2024 16:35:00.248 [23188558261048] Info — [Req#4c1] AutoUpdate: error getting data from plex.tv
Jul 09, 2024 16:35:02.199 [23188615838520] Warning — [Req#4e1] [Preferences] No update channels loaded, so showing the previously-selected channel, labelled 'unknown' since we don't really know the name.
