Server Version#:
Player Version#:1.41.7.9823-59f304c16
Hello,
I’m newbie, french and an old man, so apologize for my english.
Since 5 june, I encountered problems on my PLEX installed on a QNAP NAS TS-453D.
All worked fine on Philips Google TV, Fire TV stick, … and now PMS seems unreacheable.
I tried to update from 1.30… to 1.41…, rename Preferences.xml, uninstall/reinstall PMS, delete all authorized entries and server entry too, use the ./claimpms.sh.
Your server is having difficulty communicating with plex.tv servers, which is necessary to claim the server.
Try configuring the QNAP to use a public DNS server such as 1.1.1.1 (Cloudflare), 9.9.9.9 (Quad9) or 8.8.8.8 / 8.8.4.4 (Google).
You may also need to change the DNS settings on your PC. You should be able to download PMS and generate a claim code at https://account.plex.tv/en/claim.
Plex’s status page does not show any outages: https://status.plex.tv/. However, there could still be a local or regional problem causing difficulty reaching Plex hosts.
On QNAP NAS, when you uninstall PMS it also removes the Plex Data Folder. This will remove any existing library definitions, server settings, etc.
Just be aware of it for future updates, etc., so you do not have to completely re-create your server.
No proxy but double nat because I use an ASUS router behind BOX provider.
How can I check SSL certificate on QNAP ?
Seems that troubleshooting starts with NAS firmware upgrade.
I don’t use PLEX every day
