It installed with no issues but now when I connect to the server in my web browser using the port 32400 it loads plex but as a client to stream from not as a new server setup. Any ideas why this would be the case?
If this server is running a desktop, open a browser on the server and use http://127.0.0.1:32400/web.
or
From another machine: http://ip_of_server:32400/web
or
If you’re using Windows on your local system and your server is on Linux or OS X, you’ll need to use an application such as Putty that can create the SSH tunnel for you. You can use instructions like these for setting up the Putty/SSH connection. If following that, you would use this information:
Gateway : ip.address.of.server
Source Port : 8888
Destination : localhost:32400
Once you have the SSH tunnel set up:
Open a browser window
Type http://localhost:8888/web into the address bar
The browser will connect to the server as if it were local and load Plex Web App
Okay so I have gotten that to work but now I am unable to “claim the server” and remote access gives me an x when trying to reach the internet. I believe my firewall is turned off so I cannot figure out what else might be blocking it from working. Any ideas?
Okay I have done a complete fresh install. Brand new os install of Ubuntu 18.04 and then installed plex and I still cannot get it to reach the internet to be able to login and claim the server. This is a hetzner so they allow all ports with no forwarding. This has worked for me in the past but now it isn’t… Any help?
It is a Hetzner server so it connects just fine, I am connecting to it just fine. When I try to run the server setup Plex cannot connect to the internet. I.E https://i.imgur.com/ugERoa8.png. I also contacted Hetzner and this was there response to me. So I do not believe port forwarding is an issue. https://i.imgur.com/dlfvZ55.png
It is a brand new Ubuntu 18.04 LTS install so no firewall is active. UFW service turned off and iptables all allow.
Okay I followed that exactly, step 7 never popped up (So I never got a chance to sign in or anything) but it did run me through the normal setup. After click to the end it just hangs on finish. I.E https://i.imgur.com/tRbLoFr.png
