Gateway in passthrough, remote access drops
Server Version#:4.147.1
I have an att router in passthrough mode and before I didn’t have any issues. I recently got a new MSI GRAXE66 router that I use behind the gateway.
DHCP-fixed with passthrough set to the mac addy of my MSI router. Firewall is set for plex and I’ve tried with defender completely off.
Firewall for the gateway is completely off.
I’ve forwarded plex on my MSI.
Manually specify public port check (32400) and I’ve tried without and using UPnP and without through the MSI. The arris gateway doesn’t have this.
No matter what I try I can watch remote access say it’s enabled and drop seconds later or sometimes works and 5 minutes later on a refresh will drop.
I think it has more to do with the gateway in passthrough.
Any advice would be appreciated.
