Getting code 403, message Not Serving Client...
-Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV3
-The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.2
-The device and operating system (including version number) that PlexConnect is installed on: PC windows 7
-The local IP address of the device that PlexConnect is installed on: 192.168.1.2
-The device and operating system (including version number) that the Plex media server (PMS) is installed on: PC windows 7
-The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.2
-Where your media is stored (e.g. internal drive): internal
-The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. not sure the version number, downloaded from github today 06/11
-The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_pms = 192.168.178.10
ip_dnsmaster = 8.8.8.8
enable_dnsserver = True
**although my settings.py ip_pms = 192.168.1.2
- issue - when attempting to access a channel I am getting code 403, message Not Serving Client 192.168.1.7. I have tried the apple trailers channel as well as icefilms and letmewatchthis
change settings.cfg to have the right IP for your PMS.
I changed it but now im getting this
DNSServer : DNS request received!
DNSServer : Source: ('192.168.1.7', 60623)
DNSServer : Domain: iphonesubmissions.apple.com
DNSServer : ***forward request
DNSServer : -> DNS response from higher level
Post the contents of your settings.py and your settings.cfg as they are now please.
well, skip the settings.py file and don't touch it.
I don't see anything wrong here. This is totally fine, just telling you that aTV needed that address resolved.
https://github.com/iBaa/PlexConnect/wiki/FAQ#plex-sections–plugins–channels
You “issue” is answered in the FAQ.
I'm getting this also
<span style="font-size:14px;">Getting code 403, message Not Serving Client</span>
https://github.com/iBaa/PlexConnect/wiki/FAQ#plex-sections--plugins--channels
You "issue" is answered in the FAQ.
Closing this as it appears some people cannot read.
