localhost error
hi,
i am over on the guide step by step on windows (8),
this is my logs:
14:17:51 PlexConnect: started: 14:17:51
14:17:51 PlexConnect: ***
14:17:51 PlexConnect: PlexConnect
14:17:51 PlexConnect: Press ENTER to shut down.
14:17:51 Settings: add section PlexConnect
14:17:51 Settings: add option port_pms=32400
14:17:51 Settings: add option enable_plexgdm=True
14:17:51 Settings: add option ip_dnsmaster=8.8.8.8
14:17:51 Settings: add option ip_webserver=0.0.0.0
14:17:51 Settings: add option loglevel=Normal
14:17:51 Settings: add option enable_dnsserver=True
14:17:51 Settings: add option ip_pms=192.168.178.10
14:17:51 Settings: add option port_webserver=80
14:17:51 PlexConnect: IP_self: 10.0.0.4
14:17:51 PlexGDM: ***
14:17:51 PlexGDM: looking up Plex Media Server
14:17:52 PlexGDM: servers discovered: 1
14:17:52 PlexConnect: PMS: 10.0.0.4:32400
14:17:52 DNSServer: started: 14:17:52
14:17:52 DNSServer: ***
14:17:52 DNSServer: Starting up.
14:17:52 DNSServer: intercept trailers.apple.com: 10.0.0.4
14:17:52 DNSServer: forward other to higher level DNS: 8.8.8.8
14:17:52 WebServer: started: 14:17:52
14:17:52 WebServer: ***
14:17:52 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
and if i am open localhost on the browser i am getting this:
Error response
Error code 403.
Message: Not Serving Client 127.0.0.1.
Error code explanation: 403 = Request forbidden -- authorization will not help.
please let me know what i need to do.
Error response
Error code 403.
which is pretty normal.
what is your actual issue?
i defined the aptv loke in the guide step by step
and i am getting this log:
and when i am trying to open the trailer screen in the aptv i am getting error.
i think i am not finish the process and i miss somthing.
please try to help me to start the plex to aptv3
what error?
Trailers in unavallable try again later
What do you have the DNS server on the ATV set to?
me ip address:10.0.0.4
and your firewall is set to allow incoming TCP port 80 and UDP port 53?
yes off course
i rerun the scipt and now i am getting in the trilair screen not response from plexconnect and this is the log:
17:23:01 PlexConnect: started: 17:23:01
17:23:01 PlexConnect: ***
17:23:01 PlexConnect: PlexConnect
17:23:01 PlexConnect: Press ENTER to shut down.
17:23:01 Settings: add section PlexConnect
17:23:01 Settings: add option port_pms=32400
17:23:01 Settings: add option enable_plexgdm=True
17:23:01 Settings: add option ip_dnsmaster=8.8.8.8
17:23:01 Settings: add option ip_webserver=0.0.0.0
17:23:01 Settings: add option loglevel=Normal
17:23:01 Settings: add option enable_dnsserver=True
17:23:01 Settings: add option ip_pms=192.168.178.10
17:23:01 Settings: add option port_webserver=80
17:23:01 PlexConnect: IP_self: 10.0.0.4
17:23:01 PlexGDM: ***
17:23:01 PlexGDM: looking up Plex Media Server
17:23:02 PlexGDM: servers discovered: 1
17:23:02 PlexConnect: PMS: 10.0.0.4:32400
17:23:03 DNSServer: started: 17:23:03
17:23:03 DNSServer: ***
17:23:03 DNSServer: Starting up.
17:23:03 DNSServer: intercept trailers.apple.com: 10.0.0.4
17:23:03 DNSServer: forward other to higher level DNS: 8.8.8.8
17:23:03 WebServer: started: 17:23:03
17:23:03 WebServer: ***
17:23:03 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
17:23:19 DNSServer: DNS request received!
17:23:19 DNSServer: Source: ('10.0.0.1', 63586)
17:23:19 DNSServer: Domain: ax.init.itunes.apple.com
17:23:19 DNSServer: ***forward request
17:23:19 DNSServer: -> DNS response from higher level
17:23:19 DNSServer: Source: ('10.0.0.1', 64353)
17:23:19 DNSServer: Domain: p36-buy.itunes.apple.com
17:23:20 DNSServer: -> DNS response from higher level
17:23:21 DNSServer: DNS request received!
17:23:21 DNSServer: Source: ('10.0.0.1', 56430)
17:23:21 DNSServer: Domain: trailers.apple.com
17:23:21 DNSServer: ***intercept request
17:23:21 DNSServer: -> DNS response: 10.0.0.4
17:23:21 WebServer: serving application.js
17:23:21 WebServer: serving C:\Users\Ran\Desktop\PlexConnect-XML_templates\assets\plexconnect.xml
17:23:21 WebServer: serving  C:\Users\Ran\Desktop\PlexConnect-XML_templates\assets\utils.js
17:23:22 ATVLogger: loadItem: Library
17:23:22 WebServer: serving .xml: /library/sections
17:23:22 XMLConverter: HTTP response error: 401 Unauthorized
17:23:22 XMLConverter: No Response from Plex Media Server
17:23:23 DNSServer: DNS request received!
17:23:23 DNSServer: Source: ('10.0.0.1', 60633)
17:23:23 DNSServer: Domain: itunes.apple.com
17:23:23 DNSServer: ***forward request
17:23:23 DNSServer: -> DNS response from higher level
17:23:23 DNSServer: Source: ('10.0.0.1', 61011)
17:23:23 DNSServer: Domain: se.itunes.apple.com
17:23:23 DNSServer: Source: ('10.0.0.1', 57945)
17:23:23 DNSServer: Domain: upp.itunes.apple.com
17:23:30 ATVLogger: loadItem: Channels
17:23:30 WebServer: serving .xml: /channels/all
17:23:30 XMLConverter: HTTP response error: 401 Unauthorized
17:23:30 XMLConverter: No Response from Plex Media Server
17:23:32 ATVLogger: loadItem: Search
17:23:32 WebServer: serving C:\Users\Ran\Desktop\PlexConnect-XML_templates\assets\search.xml
17:23:33 ATVLogger: loadItem: Settings
17:23:33 WebServer: serving .xml: /
17:23:33 XMLConverter: HTTP response error: 401 Unauthorized
17:23:33 XMLConverter: No Response from Plex Media Server
17:23:35 ATVLogger: loadItem: Search
17:23:35 WebServer: serving C:\Users\Ran\Desktop\PlexConnect-XML_templates\assets\search.xml
17:23:36 ATVLogger: loadItem: Channels
17:23:36 WebServer: serving .xml: /channels/all
17:23:36 XMLConverter: HTTP response error: 401 Unauthorized
17:23:36 XMLConverter: No Response from Plex Media Server
17:23:36 ATVLogger: loadItem: Library
17:23:36 WebServer: serving .xml: /library/sections
please help
Go to your Media Manager on the server under settings, show advance settings, network, put in the ip of your apple tv in list of networks that are allowed without auth.
That worked for me with the same issue.
its working great thank you for alll !!!!!!! :D  :D  :D  :D
I'm having the same issue, my Apple TV has a manual ip address of 192.168.1.8 and I've set this in the PMS advance settings:
127.0.0.1/255.255.255.255,192.168.1.8/255.255.255.255,192.168.1.15/255.255.255.255
The computer with IP address 192.168.1.15 is able to connect without being logged into myPlex but the Apple TV still causes this error:
7:22:00 ATVLogger: loadItem: Library
17:22:00 WebServer: serving .xml: /library/sections
17:22:00 XMLConverter: HTTP response error: 401 Unauthorized
17:22:00 XMLConverter: No Response from Plex Media Server
Any help appreciated.
Which IP is PlexConnect running on? *.15, too, or something else? You might have to add this one as well.
It's running on the same server, so I thought it was covered by 127.0.0.1, I can try 192.168.1.4 which is it's ip address.
The server running plexconnect and the plex media server is also the DNS server for my network so I added trailers.apple.com and atv.plexconnect myself.
Here is my cfg just in case:
[PlexConnect]
logpath = .
enable_dnsserver = False
ip_webserver = 192.168.1.4
prevent_atv_update = True
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 192.168.1.4
ip_dnsmaster = 8.8.8.8
loglevel = Normal
ip_pms = 192.168.1.4
enable_plexgdm = True
