Trying to install Rasplex, but get error about libudev.so.0
# ./GetRasplex.bin
./GetRasplex.bin: error while loading shared libraries: libudev.so.0: cannot open shared object file: No such file or directory
Tried to install libudev, but It seems It can't found package.
$ sudo apt-get install libudev0
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package libudev0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘libudev0’ has no installation candidate
Anyone can help me get on the track? I'm using Ubuntu 13.10 64bit
However I feel that brewston solution to use dd is safer, because in that way you don't need alter your system. I have no idea what differs libudev.so.0 from libudev.so.1. Now I just blindly link them and hope that It will not mess up my system in long run.
Don't do this, this is very bad. What will happen is the GetRasplex.bin will use your new libudev as if it were the previous major version, and it isn't. Enough in udev changed to change the revision # for the release. Sure, it might work. It could also do unexpected things, and that's a bad idea with a program that writes disk images by block.
