Getting SSL errors for https://plex.tv
Server Version#: 1.42.1.10060
Player Version#: N/A
I have (had) 2 Media servers one in Ireland (on Windows 11) and the other in France (Ras pi - holiday home). I lost connectivity to the France server a couple of days ago and was getting all sorts of strange errors when trying to diagnose.
The most fundemental is “Your connection isn’t private” when trying to connect to https://plex.tv from french server in browser and also from Windows PC in France. Pinging plex.tv from France gives 54.73.99.55 as the IP. nslookup gives:
Server: unifi.localdomain
Address: 192.168.4.1
- this is local router which points to Bouygues Telecom (my ISP)
Non-authoritative answer:
Addresses: 54.72.14.50
54.73.99.55
When I try the same thing from the Ireland based server (using Windows Remot Desktop connection) I have no SSL issues and when I ping plex.tv the IP is 52.209.82.108. nslookup gives:
Server: dns.google
Address: 8.8.8.8
Addresses: 52.209.82.108
52.213.108.76
I have no VPNs set up.
https://app.plex.com doesn’t throw the error at either location.
Attempting to log into https://forums.plex.com does trigger the “Your connection isn’t private” because it first redirects to https://plex.tv for the login process
Is this a Plex problem or somewhere else in the system?
SSH into the command line of the remote machine.
Download and run this on that remote Linux machine.
(Help in the README file)
Thanks ChukPa.
I already messed up the France based linux server trying to resolve the issues. So I wiped it and will reinstall tomorrow. Not a big deal.
Do you have any thoughts on why I get SSL error when I try the URL from the France ISP? See below. This is messing up all update and/or reinstallation steps because the authentication steps redirect to https://plex.tv. Are 54.73.99.55 and 54.72.14.50 valid Pleax IP addresses with missing SSL certs or is the DNS in France pointing to the wrong IPs?
SSL does require date & time to be in tight sync in the correct time zone.
Those addresses are the Amazon AWS servers which Plex.tv uses
but I cannot get any valid connection to Plex.tv using them
Try using these addresses instead.
[chuck@lizum ~.2013]$ nslookup plex.tv
Server:		127.0.0.53
Address:	127.0.0.53#53
Address: 52.213.108.76
Address: 52.209.82.108
[chuck@lizum ~.2014]$
If these work then I will contact Operations and let them know of the problem.
52.213.108.76 and 52.209.82.108 do work for https://plex.tv at the France location.
I connected to them by overriding my ISP’s (Bouygues Telecom) DNS and using google (8.8.8.8).
