Good way to name folders?
So most of my shows arent showing because of the folder names, so i was wondering it i can do something like this to name them
S1 - title
s1.5 ova
s2 - title
and follow a pattern like that, im not sure if plex is able to do OVA,ect... Most people say to label them as season 99, but some of the shows i have have multi season/ova/movies
How is the show/series named on thetvdb.com ?
That is the format plex follows
Also this: https://support.plex.tv/hc/en-us/categories/200028098-Media-Preparation
@hthighway I am not using thetvdb.com im using a custom one and babs
@smdion Ive looked at that but for the most part it talks about epis 00... for the most part OVA are more then 1 epis (for my shows). so i want to find a way to make it so that its a different season.
Well if you’re using a custom agent you need to tell us which one, as different agents sometimes expect different naming schemes. Or check if there’s documentation for the agent.
Well if you're using a custom agent you need to tell us which one, as different agents sometimes expect different naming schemes. Or check if there's documentation for the agent.
Its the MAL one here is a link to it
https://forums.plex.tv/topic/105054-release-myanimelistnet-metadata-agent/
